AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › The Official HSU VTF-15H Thread
The Official HSU VTF-15H Thread - Page 143
post #4261 of 5097
Originally Posted by comfynumb View Post
Thank you! I watched it once but my Def Tech sub would not produce on the grenade scene, it is on it's way out but I can't wait to watch it again, and hear the bass correctly.
Throw it out on the curb.
Gear mentioned in this thread:
post #4262 of 5097
Originally Posted by PcGeek626 View Post
Just imagine what dual 15h would do. biggrin.gif great sub!
Yes, just imagine. Wait, I don't have to.............lol.
post #4263 of 5097
I dont think many 12's are worthy of HT, especially a big room. Im 15" all the way from now on.
post #4264 of 5097
Lol!
post #4265 of 5097
How are you guys breaking the HSU's in? I mean can I let it warm up and turn it up half way and watch WWZ at -10?
post #4266 of 5097
Say what? Lol
post #4267 of 5097
No, it doesn't work that way. The sub has to be set up properly using Audyssey or whatever program you may have to set up your speakers. It will tell you if your sub is set too high or too low and then you can adjust the gain. I don't think there's a situation where you would need to turn the 15H up to half way. If it's a single sub, usually 9 o'clock on the dial is about as high as you want to go.
That dial is NOT for volume, it's for gain.
post #4268 of 5097
Anybody ordered their VTF-15 with extended warranty? just thinking of peace of mind but it makes it a little pricey.
post #4269 of 5097
No, I skipped out on it. I just know that within another year, i'm going to want something more. Sure do wish they had a trade-up program more than anything else.
post #4270 of 5097
Gotcha, my Marantz pre/pro has Audyssey XT32, so I'll have to run it again once I get the new sub set up. I've never owned a good sub, just the def tech, so this is going to be like starting all over again. I mean to get that sub to keep up with my mains I had to turn the gain up to around halfway, especially for movies. Also Audyssey's 75 Db reference always seemed a little low for my taste.
Ok what is Q control? I also noticed the crossover has an on/off switch, so if you switch it off the crossover is bypassed I'm assuming. What advantages or disadvantages are there to this?
Edited by comfynumb - 9/23/13 at 5:23pm
post #4271 of 5097
Hey Comfynumb,
It was great talking to you over the phone. Welcome to the Hsu Family! The Q control slightly adjusts the deeper bass roll off. What you generally hear is a tightening of bass. You can reference the response graph on our main VTF-15H product page:
You are correct, switching the crossover to, "out" will bypass the crossover setting. In many cases, bypassing it would be a good idea if you have your av receiver handling the crossover.
Sincerely,
Kevin
The Hsu Research Team
post #4272 of 5097
Originally Posted by HsuKevin View Post
Hey Comfynumb,
It was great talking to you over the phone. Welcome to the Hsu Family! The Q control slightly adjusts the deeper bass roll off. You can reference the response graph on our main VTF-15H product page:
Sincerely,
Kevin
Hi Kevin, thank you! Also thanks for the quick email responses and I have a tracking number already, very impressive service. Ok, I understand and I'm guessing my pre has the ability to set the crossover where I want it. I'll have to inquire on the Marantz thread because I've never done the crossover that way.
post #4273 of 5097
No problem, glad I can help! What Marantz preamp are you running?
Sincerely,
Kevin
post #4274 of 5097
Sincerely,
Kevin
I bought the new AV8801 about 8 months ago.
post #4275 of 5097
Oh very nice. It should have a manual setup where you can set the speakers to small and the crossovers for each of the channels.
Sincerely,
Kevin
post #4276 of 5097
Sincerely,
Kevin
Thanks, it really is a great pre. Yes I can do it that way or let the sub EQ set it when I rerun Audyssey. The guys on the 8801 thread are telling me to let sub EQ set it up so I'll post my results afterwards.
Edited by comfynumb - 9/23/13 at 7:12pm
post #4277 of 5097
post #4278 of 5097
Audyssey, Audyssey, Audyssey.
post #4279 of 5097
Yes, be smart about it. Honestly if you turn up the gain knob and press play before running audyssey or calibrating all your channels even then you will be prob like 20db hot and then disappointed when you run Audyssey and it's flatter. I had mine corner loaded and set the gain to about 830 which gave me -2db and then I ended up +2db with bumping it up in my AVR.
post #4280 of 5097
I will definitely take the time to set the Hsu up correctly with sub EQ. It seems I'M stuck in my old sub mentality and I need to wipe that from my memory biggrin.gif
Edited by comfynumb - 9/24/13 at 3:19am
post #4281 of 5097
Is it a bad idea to put the 15h in the same room as a 150 gallon fish tank?
post #4282 of 5097
Originally Posted by Super3Goku View Post
Congrats!
post #4283 of 5097
I debated this and decided it was not in the best interest of the fish, I'm pretty sure they'd freak out biggrin.gif
post #4284 of 5097
You heard the 'Darla tap' on Finding Nemo, I think that would be the effect the fish would feel in the same room with a VTF in it.
post #4285 of 5097
I'm more concerned with the tank & 150 gallons of water being all over my room
post #4286 of 5097
When you run audyssey, a good setting to have the subwoofer on is 1 port open, EQ 1, Q.7, crossover set to out, and volume at 9-10 o'clock position. After you run audyssey, feel free to experiment with the different settings.
Sincerely,
Kevin
post #4287 of 5097
Sincerely,
Kevin
Will do thanks Kevin.
post #4288 of 5097
post #4289 of 5097
Congrats!
post #4290 of 5097
Awesome! Enjoy!
