I had a quick question for those of you that are knowledgeable about LCD's. I just purchased a 42" Vizio E470VL LCD and noticed a horizontal band a little more than half way down the screen. By band I mean that the screen is a tad darker in about a 2 inch band horizontally across the entire screen. Is there a setting that can remove this band?? Is it a problem with the TV itself?? The band appears no matter the input so it isn't an input problem.
If you can help or at least tell me the TV is shot I'd be appreciative.
