AVS › AVS Forum › 3D Central › 3D Tech Talk › Subtitles For 3D movies ?
Subtitles For 3D movies ? - Page 2
post #31 of 34
Is there any easy program that create 3d subtitles from simple srt files that samsung 3d tv's support.
Already try the 3dsubtitler and i was try both idx/sub or sup internal or external on 3d mkv files but neither of these it works.
It worked ONLY with external media player product NOT WITH SAMSUNG INTERNAL MEDIA PLAYER WHY IS THAT HAPPENING?
post #32 of 34
Please try GOM player
You may search it from google and it is free
post #33 of 34
ONE MORE TIME....
I DON'T WANT PLAYER but program that can convert the simple srt subtitle file into 3d subtitles files the gom player you suggest me IT DOESN'T DO THE WORK i want so is useless...
post #34 of 34
I have tried what you suggest, but the program doesn't recognize or accept the sub file I created with 3DSubtitler.
Also the file Tsmuxer creates is a TS file, not an MKV file. How will MKVMerge accept that?
  Back to Forum: 3D Tech Talk
