AVS › AVS Forum › Audio › Speakers › on wall, axiom, SVS, HSU
post #1 of 3
all,
am looking for some relative cheap surround / on wall speakers.
But they need to be able to make some noise and play detailed
so far:
Axiom QS8
HSU HB1
SVS SCS01m
SVS SSS02
Any comments on these speakers ?
post #2 of 3
Originally Posted by subbass View Post
all,
so far:
Axiom QS8
HSU HB1
SVS SCS01m
SVS SSS02
IMHO, you'll have to spend a heck of a lot more money to do better than SVS. I have both 5.1 and 7.1 SVS systems, the 5.1 system using all SBS-02s except for the SCS-02 mid and PB12NSD sub. The 7.1 system uses the STS-02 slim towers as mains, an SCS-02 mid, SSS-02 side surrounds, SBS-02 back surrounds, and a P12NSD sub.
Both systems sound incredible. I did tweak the top end EQ on both systems from about 8K to 16K, +1.5db, for my personal taste and just to open up the top end slightly. To reiterate, both systems sound fabulous without any tweaking whatsoever, but I just like to hear the "shinnnnggg" and overtones of the acoustic guitars, mandolins, banjos, and other acoustic instruments. And I get that in spades with both systems. Like I said, just a personal preference. Both systems reproduce very accurately and are tremendously transparent. After a month or so of listening to both systems I can't recommend SVS highly enough.
A word of warning...if you like your sound system baseline sound very colored look elsewhere. SVS is well known for producing highly accurate speakers. I prefer a speaker system with a highly accurate, transparent, and flat baseline so that I can take it from there, if necessary. That way I'll have a point of reference...a baseline for comparison. There's absolutely nothing wrong with wanting a "colored" system, one that emphasizes lows, mids, or highs to an extent. It's all personal preference. I prefer as accurate of a baseline as I can get...or afford. SVS will get you there, for much less money than most. At least that's been my experience. Just an extremely satisfied customer...no connection to SVS.
Tom
post #3 of 3
As with all comments, even mine, take them with a grain of salt as only your ears can judge which is best. You have to decide if you want a direct radiating speaker for the job or a more diffuse/enveloping sound. Once you have this set you can decide on speakers.
I like a more diffuse sound so I recommend the Axiom QS series. They are highly touted as one of the best surround sound speakers available, I have a set and love them. They offer a very diffuse sound which is what the speaker arrays in an movie theater do, only you use just the 2 speakers instead of a few for the side surrounds.
Emotiva also has a multipole surround speaker it maybe worth a look. I have never heard it and the one review comments to it being better than the Axiom QS series.
  Back to Forum: Speakers
