AVS › AVS Forum › A/V Control & Automation › Home Automation › X10 XPCR Wiring Help Needed
post #1 of 3
I wired in my XPCR as shown in the diagram, but I'm not seeing the red led light when sending X10 signals.
Here is how I had it wired. Any help would be appreciated:
post #2 of 3
Well, it is one of three things:
  1. The device is defective and just plain doesn't work
  2. The device works, but the LED doesn't
  3. The wires are not making a good connection
Can you reliably control devices on one leg from a from a transmitter on the other?
Is that 50A dual pole breaker you hooked up to rated for two wires put pole? I doubt it. Did you read the instructions that say the device is to be hooked up to 15A breakers?
post #3 of 3
[quote=Colm;19449914]Well, it is one of three things:
Got it working now. Thank you.
  Back to Forum: Home Automation
