Originally Posted by naz4viper
hi Charlotte TWC folks
I'm looking to start service with TWC cable (internet + TV) sometime in near future, but I dont want to spend any more then is absolutely necessary
my tv is the Samsung PN50B650 50" plasma which apparently has built in Clear QAM digital tuner. I dont think my TV is CableCard compatible.
My question is this:
-what service do I need to ask for in order to utilize my TV's tuner instead of paying an additional $11/month for HD/Digital set-top box ? If I can utilize my TV tuner and pick up most (if not all) my channels in HD that I would normally get from the set-top, i would much rather go this route and save the money. I dont mind losing features like on-screen guide or Start Over, etc..
- what are other down sides to using built in QAM tuner instead of set-top box?
Thanks!!
Thanks!!
You will only get the local broadcast stations (main and most subchannels) in clear QAM. A few other SD channels are consistently available, such as the local TWC news channel. There are no clear QAM HD cable services at all. Virtually all cable services are both encrypted and SDV (switched digital video - services are carried only when someone is actually watching and physical channel cab vary from session to session).
For more or less "full service", the only real alternative to renting a box from TWC is to rent a cable card from them and plug it into a third party cable card tuner that is compatible with SDV, such as units available from Ceton or SiliconDust. The necessary SDV tuning adapters are "free" from TWC.
