Hi everybody I just wanted to contribute with my two cents. I have an 46 HX729 and I'm using Omar's calibration settings except that I put the motion flow in standard. I'm loving every bluray that I watch. The smooth motion flow feature create a lot of ghost in movies, sure you can put it in auto 2 and everything seems fine but auto 2 isn't working on the bluray, that is why it seems that it is better. Auto 2 is more for sd programming. (not always) BTW remember to change the white balance to Omar's set, it helps a lot.
I'm also using this calibration with the 3d obviously using auto 2 because its the only one that can be used except of off. But I put the picture setting at max and in white balance I leave everything at 0 except the first red bar, that I put it on -1.
I hope these tweaks to an already awesome calibration helps you out. Cheers!
