AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Fetch's Theater Build - 95% complete!!!
Fetch's Theater Build - 95% complete!!! - Page 4
post #91 of 176
Originally Posted by cdika17 View Post
will never use the whole screen because of masking it down to proper size. 120" wide is as wide as it will ever be.
If I understand this correctly, you determined what size 16:9 image you wanted and then came up with a 2.35:1 screen size that could still accommodate that 16:9 image. Is that how you arrived at 160" wide? Why aren't you planning on using any of the extra width for 2.35:1 movies? Your description above makes it sound like you don't plan on going larger that 120" for either format. If that's the case, you could just get a 120" wide 16:9 screen and simplify your masking.
post #92 of 176
Im installing OSB right now onto my ceiling channels, can you run the sheets parallel with the channel or are you supposed to go perpendicular?
Figured it would be best to run the first layer of ceiling OSB parallel to the channel and then the second layer drywall running perpendicular (the normal way) to the channel. If the panels should be installed perpendicular to each other for seam overlapping purposes, one layer will obviously have to run parallel to the channel?
I am only a couple sheets in and want to make sure.
Edited by cdika17 - 10/1/12 at 7:48pm
post #93 of 176
Ugh 5/8 OSB, finally done, on to green glue and 5/8 drywall tomorrow am.a9a6esed.jpg
Chase "Fetch"
post #94 of 176
Looks like some good work there. Keep it up.
post #95 of 176
Drywall on ceiling is done, doing the walls tomorrow then mud tape guys come Tuesday!
post #96 of 176
Few pictures, messing around with panorama option on iphone5.
A bit more sealant to put on then it's on to the walls. Didn't work in room very much today being it's our Thanksgiving in all. Pushed the mud/tape guys to Thursday. Then on to stage, riser and soffits.
Chase "Fetch"
post #97 of 176
Drywall finished finally, ugh, should of just hired it out. Got a guy coming to mud and tape this week, if he will still come! Cancelled like half dozen times already.7ahupedu.jpg
After mud/tape/sand ill spray on a coat of primer sealer on everything then get to work on riser then soffits then sand filled platform for behind screen where speakers will sit, not doing a stage.
Chase "Fetch"
post #98 of 176
I bet it feels good to get that done. Looks great. Hope your finishing guy doesn't flake out on you so you can keep things moving. What made you decide against a stage?
post #99 of 176
I like the clean look of no stage, like chartrands build, couple pics for reference.
Also a stage is more inviting for the kids to go up and play on near screen, after all the time/effort/money, id be little irritated if I came home and there were holes or something in my screen, just personal preference i guess.
Ill still have a platform similar to Chartrand, using roofing felt with 2x10"s filled with sand and double 3/4" plywood. If i have enough green glue ill throw some on between layers.
post #100 of 176
what size image did you arrive on
post #101 of 176
Well I am still kind of researching, which I do way to much of and looking like a 2.37 130" wide Seymour, this will give me a 110" Dia 1.78 image for sports and gaming and is the size I currently was using, I didnt want anything smaller than 110" dia as I thought that was perfect for my room for 16:9 viewing and then ill get the added bonus of a 130" wide scope screen which will be sweet for blu rays. The 2.35, 2.37, 2.40 ratio debate is still on going but more screen suppliers are coming out with the 2.37 ratio and must be on something for projectosr with CIH zoom abilities.
post #102 of 176
I use an anamorphic lense and I'm at the shorter throw range, so I have a 2.41 image (i.e. slightly skewed).
In my opinion, go large 2.4. This sounds terrible, but with 1.78 I still keep my lense in place - because it fills the screen (by zooming) and crops a little bit off the top and bottom. That's how much I don't care about 1.78 anymore!
Once you see epic movies in larger than life, you won't want to go back...
You want to talk about researching it took me 2 years to buy my projector, and now 5 years to build it's room (researching how to do it). My carpenter that's helped me do some things thinks I'm crazy and wants to know what it's all about.
I told him recently he will be disappointed because once my room is finished it's not like I'm actually going to use it, I just like building it out.
post #103 of 176
I mostly watch sports, i'd say 50% sports/tv, 40% movies & 10% gaming. So a decent sized 1.78 image is a must also for the kids and there kinect/wii. But want the 130" scope for movies.
post #104 of 176
Here are some more sketchup designs of scheme and looks:
Almost looks to boring to me but who knows, different panel layout and possibly another added color would spruce it up or a nice offsetting carpet to bring it all together. The more you deviate from nice long panels the more work it becomes, so it will come down to how i'm feeling during the home stretch.
Inspiration:
post #105 of 176
Another idea:
post #106 of 176
FWIW I don't particularly like the lighter tan. I really like what you've got going in post 108.
Not to mention you'll make a career out of putting fabric on that door!
post #107 of 176
The wife thinks just black and brown are boring and thinks adding another color would look better. So I'm trying to amuse her. Maybe more panel designs with the 2 colors similar to my first render and same idea as bacon race.
post #108 of 176
Mud and tape finished!!!
Gonna start primer/seal hopefully tomorrow, then on to the flat black paint everywhere.
Would it be preferable if I used Behr Premium Plus Paint & Primer in one?
http://www.homedepot.ca/product/premium-plus-ultra-interior-flat-enamel-paint-primer-in-one-189l/924125
I will be spraying it on with this:
http://www.homedepot.ca/product/procoat-piston-pump/983086
post #109 of 176
I would recommend priming it with a new drywall primer/sealer first and then a high quality paint for the areas that will not be covered by acoustic treatments.
post #110 of 176
PVA drywall primer normalizes the absorption rate differences of the drywall paper and the mud, and it is cheap. will help the paint look more uniform.
post #111 of 176
And can I spray on primer or should i roll it?
post #112 of 176
Roll it. You need the primer to make good contact with the drywall. If you wanted to you could spray it and backroll it. Probably easier just to roll it the first time.
post #113 of 176
I almost had the mudder/tapers do it but they are busy now.
Off to HD in the morning.
BIG, there are not many positive reviews on PVA drywall primer, wonder why that is. Thinking I may go with the behr stuff.
post #114 of 176
I had good luck with Sherwin Williams drywall primer. Added a tint to make it dark. Went on really well. Gets a thumbs up recommendation from me.
post #115 of 176
2 coats?
post #116 of 176
I'm trying to remember. I think I only did one good coat because I was covering most of the walls with fabric and what wasn't covered was going to be black. Worked so well that my wife wanted to use the primer color elsewhere in the house.
post #117 of 176
The primer probably got bad reviews because the people who bought it didn't understand what it was for. That, and it's Glidden smile.gif
Seriously, the primer soaks into the board.. you will still see all the mud joints and nail holes. But that's what it's supposed to do.
You can definitely spray it.. the stuff will soak in, no need to roll.
Tim
post #118 of 176
Lame update but 2 coats of primer on!!
Now waiting for my table saw to arrive and I can start the rest.
post #119 of 176
Fantastic so far, very informative and it's going to be fantastic when done. BTW northern Alberta boy here too, just 5 hours further north of you. biggrin.gif
Just starting my build(not nearly as involved as yours) and if you think its hard in Edmonton to get supplies try up here.
Hope to see an update soon.
Robin
post #120 of 176
I'm in Grande Prairie, hope to start riser and stage next weekend.
