Originally Posted by
AirBenji
Chase - looks very well thought out. My only suggestions would be to be sure that you have two quad 20 amp outlets in your equipment location and to stick an HDMI connection in the face of the riser. (Maybe you're already planning on this with those Cat5e cables...I'm showing my ignorance because I don't know how that works.) You never know when you may wish to plug in a game system or some future doohickey etc.
I was thinking i may run 3 20 amp outlets to my storage room. 2 for my amps and 1 for my APC H15 that will have the rest of my equipment plugged into. I plan to run powerbridge for the 2 subs up front and the projector to the storage room. Should i plug the subs, projector and the rest of my av gear all into the H15? Or should i get maybe a S15 that has battery backup for say the projector, htpc and server?
Reason i didnt have hdmi going to riser and use cat6 instead is beacuse my racks are in storage room behind screen wall and the time i route everything down to riser, ill be close to 50 feet and figured hmdi over cat6 would be better option.
I will be running 2 hdmi to projector, they will be 40foot cables, wonder if I am stretching it abit with length on these?
