Nice looking speakers! I think they fit the room more so than the ones they replaced. I also like those outriggers but just can't find it in me to drop that kind of coin on 'em.
Originally Posted by
Jed K.
Regarding Looneybomber's phase plug issue... if there is noise coming from the phase plug it is likely dust or debris that got into it, which can be removed with compressed air blown into the gap and/or gently depressing the cone evenly up and down to work any debris/dust out of the voice coil. If I would have known there was an issue, I'd issue you a return tag to Parts Express no questions asked. Although as I recall, 8 of the woofers were purchased from a 3rd party? Either way I'll take care of my customers if an issue is known. The parts carry full manufacturer's warranty.
You're exactly right, 8 were purchased from a 3rd party, which is why I was going to go through PE. The dust/debris issue would happen free-air along with being mounted, but I only have the problem when it's mounted.
Jed K.
As for the T/S parameters of the new Dayton RS180-8 drivers, since you suspect 3 are bad (after trying above suggestions), I'd use the new RS180-8s replacements from PE in the CC and maybe purchase 1 more to make a matched set. Then change the port tuning to the 3" Precision Ports with a 7.5" length end to end (requires a new port tuning because of the different parameters). If the old RS180s drivers are indeed defective, PE will warranty them. I hope this helps, and if there is anything else I can do just send me an email.
www.clearwaveloudspeaker.com
Jed
I'll keep you posted on what I find out after contacting PE, however, I want to test all 12 drivers to see if there are any others that need replaced.
