AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Vizio xvt3d554sv
Vizio xvt3d554sv - Page 56
post #1651 of 1665
Can your laptop graphics card drive a 55" monitor at 1920x1080? And if so, have you verified that the output signal from the laptop matches one of those recommended by Vizio in the TV's manual? The TV may have very specific requirements for displaying a signal from a PC via HDMI as opposed to VGA.
Edited by Rudy1 - 8/25/13 at 12:02pm
post #1652 of 1665
I'm not sure how to check your second question, but the Laptop appears to be able to support 1920x1080, that is one of the options to select when adjusting the resolution for the secondary (tv) monitor.
post #1653 of 1665
Check your video card's settings and try each of the output options for 1920x1080 (24Hz, 50Hz, 60Hz, etc.). One of those may work with the TV.
post #1654 of 1665
My HP Laptop has the ATI video and when I use it I have to go in and enable it in the video setting. I select Clone so it displays the same on both the Laptop and TV.
You could also try rebooting your Laptop while it's connected to the TV and see if it will automatically enable it. If the resolution is wrong you will get "Invalid Format" on the TV screen. No Signal usually means it's not enabled.
post #1655 of 1665
This may be stating the obvious, but many laptops use a key combination like an Fn key and a function key like F8 to cycle the video output from laptop panel to video output to both with sequential key presses. I know this is frequently done with the external VGA output. I haven't had a chance to work with a laptop with HDMI so I don't know it that output works the same but it might be worth checking. Maybe the laptop is in panel only mode.
post #1656 of 1665
I see both the Sam and Cost Warehouse stores have the VIZIO S4251w 5.1 soundbar on sale for Black Friday at $199. I'd like to replace my 5.1 home theater setup with a less confusing one for my wife....
My questions are does anyone have experience using this soundbar with our Vizio model? Will our set pass 5.1 Dolby thru the optical cable? How does it work with a DISH network remote? Obviously how is the sound vs a real amp? Can you shut off the sub woofer for late night use? I'd like to hear your thoughts on the sound bar. Thanks in advance. biggrin.gif
post #1657 of 1665
Ok, so the last few days my picture has been going black for 1-2 seconds at a time. I thought it was something to do with my playstation but today it happened while I was just watching tv. Any ideas?
post #1658 of 1665
It seems to only happen when I'm using picture in picture.
post #1659 of 1665
This happens if you have Game Mode turned on. Double check your settings.
post #1660 of 1665
Game mode was turned on. Thanks man!
post #1661 of 1665
Well I bought the Vizio 5.1, and now I'm returning it. Good sound, but only has two digital inputs (a TOSlink & Coax). If those two connectors will meet your 5.1 input needs its a winner. HOWEVER, 99.9 % of TVs DOWN CONVERT HDMI 5.1 audio to 2 channel for their digital output so you can't use the XVT3D has an HDMI switcher into the soundbar and get 5.1 sound from your Bluray, DVR or Roku etc. The only way you get 5.1 sound out of a modern TV's digital connector is if the 5.1 sound is generated in the TV itself (an Over the Air 5.1 signal or a 5.1 internal widget). Maybe in the future I can get rid of my AVR 5.1 system. I hope my experience is useful.
post #1662 of 1665
Been experiencing an exciting new glitch with my TV.
All of a sudden, without nary a warning of any perceptible event, the TV picture disappears and I'm looking at a grey screen. Happened about 3 times in last 2 weeks. No matter what I do, it shows nothing from any source. Not even it's own onscreen menu. Nada, Nein, Bupkis! Only a shutdown and restart fixes it. Damn, Damn!
I've already had both boards replaced within 2 years. WTF????
The picture is great when this thing works, but at least for me it's been way too much failure. This sucks big time. Never will i buy another Vizio.
Or is it just me living under a star crossed cloud of bad luck?
post #1663 of 1665
I'd say it is bad luck, mine has been problem free. Having to repair a device early in its life cycle indicates either a poorly assembled or poorly designed model and usually doesn't end well. I can understand your frustration about buying Vizio again. On the bright side, with 2014 models arriving in March and pre Super Bowl sales you should be able to find a nice replacement at a reasonable price. Hope things turn out ok.
post #1664 of 1665
Sorry you have been having problems. In today's world I expect electronics not to break for a very long time. Mine has been flawless as well. Amazing picture. But, it does not get heavy use and I have never connected it to the internet.
Fred
post #1665 of 1665
Mine stayed with me for about six months, then I just got fed up with the horrible crosstalk and sold it to a guy who had no interest in 3D. I just found out recently that the dude had a major fight with his girlfriend, and she poured a can of soda down the back of it...exactly one week after he bought it from me. eek.gif
