Originally Posted by GoLaLakers
The view is only of the back yard, I just don't want to be in a completely black room when watching a game at noon. I am thinking a 3%-5% shade will probably do the trick. So dark brown/reddish colors would reduce glare? Also, do these shading solutions do anything to keep the room cool or warm during the seasons, or are they strictly lightning control and privacy?.
Darker fabrics will reduce glare and allow you to see through them better (kind of like sunglasses) and because the darker color is absorbing the light it helps to darken the room even though the view is preserved. If you get a lot of direct sun (which you don't) they make performance fabrics with aluminized reflective backing or just white backing that reflects the light/heat out. You might notice a slight increase in temp in the window with a darker fabric as it is absorbing the light (like a black car), but it is blocking 97% of the light from coming in so it cuts heat as a whole. Also having something in the window is better than nothing and does form somewhat of an insulating airgap behind the shade, but roller shades typically aren't know n for their insulating value. Most of the fabrics favored for residential use don't offer a lot of performance options, but there are some. The metalized back fabric can be a little delicate and show rub marks on the metal side, but it is great if you are careful with it. PVC fabrics are durable and cleanable but may off gas some PVC smell for a while, FYI.
I am going into the show room this week to compare the Somfy options with Lutron. What kind of control options do I have with Somfy? Can I use Ipad/Iphone to control the shade? If I eventually upgrade to Control 4 or other home automation solution, can the Somfy integrate easily? It's only 1 window for now, but we might eventually expand into some of the bedrooms.
You can think of Lutron like Apple they offer a great product at a premium price, but it is trying to be a closed system. Their products do the same thing as other motor manufacturers, they just do it smoother/quieter. Somfy is used by everyone (including Lutron) and so control options are open and many, like non-Apple PCs. Crestron fully supports Somfy motors, wired or radio. If you insist on using Radio control and not wiring for control, then Radio RA2 is newer and better than Somfy's RTS Radio. Z-Wave Radio is better than both options and would just require using a standard 4-wire ac-motor and separate Z-Wave motor controller or the Somfy ILT Z-Wave setup. It would be compatible with many Z-Wave enabled systems (gateways, lighting controls, HVAC, locks) that offer iDevice control. Somfy is soon to release their Z-Wave system called Tahoma (strictly lighting, shades, and HVAC), but like I said there are other like Homeseer, Micasaverde, etc. I have my entire house controlled via iPhone and I chose Z-Wave because of its open protocol and affordability. Lots of different options. All of this would require a knowledgable salesperson/installer and or a bit of effort on your part to get the system together. So if you want a packaged solution and are willing to pay extra, then Lutron will give you that. If you are budget concious and willing have some input on the components of the system then go Somfy. Don't let anyone tell you that something won't work with something else, there is always a way to make things integrate with eachother. Lutron keeps presssure on its dealers to maintain a certain level of sales and the end result is Lutron gets pushed on every customer whether or not it fits their budget or feature needs. It is best to try to offer everything and tailor the system to the budget and needs of the user.
edit: Go Lakers! (yes I'm in So Cal)
