Originally Posted by ninja12
Setting the sub to Flat gives you a little more oomph with the low frequencies because ARC doesn't roll off the low frequencies when the setting is Flat. ARC passes all of the low frequencies to your sub for your sub to handle. However, you should only set your sub to Flat if your sub has built-protection, which means it will not try to play frequencies that it's not capable of playing, and your sub plays with good volume down to 20 Hz. If your sub is not capable of those two requirements, then leave it set to Auto. With Auto, ARC will determine the low end capability of your sub and roll off the low frequencies to make sure that your sub doesn't try to play them.
May change the setting to "Flat" today and re-upload. Based on your experience, would it possibly make sense to do this for only the Movie config or do you think Music will benefit? My uneducated "gut" tells me that I'd lose some tightness in the music if I set that to flat.
Thoughts?
