AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide
Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 435
post #13021 of 14626
Originally Posted by scirica View Post
I have the same combination (Oppo 93 -> MRX 500 -> Panasonic plasma (VT50)) and my calibrator Jeff Meier stated the following regarding sending the video through the Anthem:
"The Anthem in your case is deleting all information below at least 5% signal level and maybe higher. This is causing the information below that to be lost resulting in the image looking too dark with no low light level detail. There could be more errors, but I did not look for others once this one was found."
I still go through the Anthem's HDMI connection but use the "Through" setting for video. I'm not positive that the difference is discernible to the eye but it is definitely measurable. Anthem has come on this thread to say the blacks that are being cut are blacker than black and therefore immaterial.
K. Miller calibrated my display and I noticed an improvement in PQ with direct hook up to display.
post #13022 of 14626
Brian-HD said: The green screen is from the Oppo. I had the Sony 790, and the Panny without green screen connecting to the MRX. I have the 105 which was connected to the MRX without green screen.
Really? So it must be the 93, if you have the 105 hooked up and it is not doing it. What is your order of power on sequence for your VT50, 105, and MRX?
post #13023 of 14626
Originally Posted by Spurrier Sucks View Post
This is an Anthem problem and not a bad hdmi cable? Glad i checked in because I was about to replace my hdmi but may try this now instead. Thanks! Anyone else having handshake issues with the Oppo 93 and Anthem combo?
As per Oppo, Anthem should update their FW to fix smooth HDMI connection.
post #13024 of 14626
Originally Posted by Brian-HD View Post
It is an Oppo issue and maybe an Anthem issue.
Check my post above yours, #13022
post #13025 of 14626
Display >MRX> Oppo (105) but it did not worked with any changing of tuning device first when I had the 95. Sony 790 and Panny 500 was vert smooth.
post #13026 of 14626
Display >MRX> Oppo (95) but it did not worked with any changing of tuning device first. Sony 790 and Paany 500 was vert smooth.
Thanks! I tried different sequences too to no avail. Thought maybe I missed something. When you had your 105 connected direct to MRX you had green screen flash? Or do the newer players (103/105) eliminate the problem?
post #13027 of 14626
There was not any green screens
post #13028 of 14626
Right now I do have HDMI 1 from Oppo 93 going straight to my Panny VT50; HDMI 2 goes to Anthem for Audio. So far so good. My panel has almost 100 hours on it and will most likely be calibrated by Jeff Meier in January.
post #13029 of 14626
I recently saw the measurements from the old (2009) Olive et al. blind preference test of room correction systems, and something struck me that I didn't notice before.
The major difference between an early version of ARC (ranked second-to-last) and RoomPerfect (ranked third) is the amount of "room gain." (ARC does seem to do a better job in the midrange, but marginally so.)
ARC more-or-less levels off the bass after accounting for the upper-bass swell, whereas RoomPerfect keeps adding boost.
image?pagenumber=24&w=800
Copying the RoomPerfect curve should be pretty easy to do with ARC an externally powered subwoofer.
Anyone tried targeting a continuously rising bass response rather than the standard room gain "step"?
post #13030 of 14626
I am sure that he will inform you of the same conclusion.
post #13031 of 14626
Hey Brian, not sure what you are saying Jeff will inform me of?
post #13032 of 14626
That it is better to connect directly to display compare to MRX pass through.
post #13033 of 14626
Agreed. Was confused on the "will" inform me. He calibrated my last display so I've already received the advice once. He'll be back in January to calibrate the VT50 and I'm sure I'll here it again wink.gif
post #13034 of 14626
I have an Oppo 93 running through my MRX 700 and have no handshake or green screen flash issues. You need to turn off some of the Auto Detect settings in the Oppo (which assuming you know your TV's capabilities should not be an issue). Once you do that, the handshake occurs much faster and the green flash is eliminated.
I posted up a long time ago the settings that I changed, but can't remember them all now (you could do a search on this thread for Oppo and my user name and find them I'm sure). Looking at the setup menu though, you can simply set all settings that are auto to the appropriate value to match your TV and I'm sure you will be all set.
post #13035 of 14626
Your settings do not eliminate the handshake issue for everyone, maybe in your setup. Do you use passthrough?
post #13036 of 14626
Hey guys,
I've owned my MRX 300 for a little less than a year and its been great. I have noticed that when I have the bass at +2 or +4, their is distortion. I can't hear the distortion until I'm up close to the speaker, but I still don't want it to happen. I only notice it during bass heavy songs. It sounds like their being overdriven even when the volume is at low levels. It just doesn't make sense. The last thing I want to do is send it for repair. What if I bought a new amplifier for it? Any responses are appreciated.
post #13037 of 14626
My settings are not set to auto. I have green flashes all the time at start-up with my Oppo BDP-93 & PS3.
post #13038 of 14626
Good news for those of you on the fence about buying a Mrx,I just got back from my local anthem dealer and he told me all new orders for Mrx"s have all been up to date on all firmware updates inc. For the opposed and they have taken care of all the HDMI issues..he said there will be no problems with any future Mrx purchases..so I ordered one!
post #13039 of 14626
I meant oppo firmware updates
post #13040 of 14626
Originally Posted by TheBuffaloBills View Post
Hey guys,
How do you know the problem is not your speakers? I used to have a 300, now a 700 and no matter how high I've driven either, I have never detected distortion or clipping in the least.
post #13041 of 14626
post #13042 of 14626
Yes...he told me he just got a order in from anthem of 10 mrx500s and anthem assured him they have all been updated with all the firmware updates inc. For oppo blue ray players and are 100% bug free..at least that was what he was told!
post #13043 of 14626
Are you on the latest firmware? There was an older firmware (much older) that had this issue. Then there was an Oppo firmware that also had the issue, but Oppo released an updated firmware that fixed it. Since I have had updated firmware (now a couple of revs behind on Oppo, current on MRX) I have not had any issues with the green flashes.
When I originally posted my settings for the Oppo, I recall they seemed to be working for others as well.
I'm currently using passthrough with my Oppo, I have not tried it as Auto or 1080p60 on the MRX in a long time.
post #13044 of 14626
My 93 has the newest firmware, my MRX-500 is on 50.25 which I believe is the newest.
post #13045 of 14626
If you are having this with your PS 3, it is likely the Anthem. From my discussion with Oppo, Anthem AVR does not work well with other devices. Did you had a previous AVR?
post #13046 of 14626
Yes, I have had two previous AVR's and never noticed the green flash screen at start up. I have owned a Denon AVR-3808 and an Integra DTR-70.2
post #13047 of 14626
I recently bought an MRX300 and I was coming from a Pioneer Elite VSX-92TXH for the last 5 years. Since 2009 I had run a Monoprice High Speed HDMI 1.3a, Category 2, 22AWG 25 foot cable to my Mitsubishi projector in our theater with no problems at all. Once I switched to the MRX300 I got nothing but handshake issues(green flashes) and I couldn't use the "through" setting without it shutting down my projector after about two mins. Even setting the MRX300 to the projectors resolution of 1080p didn't work without shut downs and flashes.
As a source I was using a PS3 and Comcast DVR and both had the same problems going through the MRX300, but without the MRX300 they worked fine going directly to the projector and through my Pioneer receiver for the last few years. I ordered a Monoprice 30ft Slim Series High Speed HDM Cable w/ RedMere (which is a powered cable) and everything works in now. I can use "through" on the MRX300 and get the sources native resolution to my project or I can set the MRX300 to 1080p and let it upconvert things with no problems. I just leave it at "through".
Just thought I'd chime in and see if this info helps anyone. Here's a link to their powered RedMere cables. http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10255
post #13048 of 14626
The green screen is the Anthem.
SO few of you seem to have a DVR.
But it's not consistent. Any time there's an ON/OFF or resolution change or Input change it "CAN" do the green screen.
And it's NOT the "Video Mute" option, mine is set to Black.
I've had four AVR's/AVPro in the last year, the Anthem is the sloppiest and inconsistent HDMI switching of the group, except maybe the Cary C12.. Sometimes a green screen, blank screen, the mess screen, occasionally a CODEC POP, you never know the combination for the same actions. Definitely not the 1/2 second black screen of a, let's say, Marantz. It works reliably, but it has the finesse of 1970's Soviet manufacturing precision.
post #13049 of 14626
If using a DVR you should be able to reduce the green which is an HDMI handshake by setting the DVR to output a specific resolution all the time versus letting it output the resolution each channel broadcast. By letting the DVR output whatever resolution the channel is broadcasting, an HDMI handshake is required every time you change to a channel with a different resolution from the previous one you were on.
post #13050 of 14626
^ that works for me. No green screen ever with PS3, LG DVD and 2 different DVRs.
John
