On your left front you have a 12db drop from 60hz to 80hz. I believe this is why
It set your fronts to 80hz. On your right front you have a large 15db drop from
Approx 120hz to 180hz. ARC has tried to correct this drop but it is still showing
An aggressive dip.
On your sub it is not important that it follows the target. You want to have a smooth
Even response from 120hz Down to 20hz..On your sub the freq response is dropping
22db (huge amount!) from 60hz to 90hz. This is why ARC set your sub to 80hz.
Please check out pages 93,94 and 95 of this thread. It shows how I
And member "litlegi74" solved our subwoofer problems. Look carefully
At the before and after graphs and you will see what I mean.
Edited by grasshoppers - 3/19/13 at 9:42pm
