AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide
Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 511
post #15301 of 16455
Originally Posted by bkeeler10 View Post
Only 7.1 pre outs. There's no mention of HDMI 2.0 so I assume by its absence that it's not there. The signage calls out Fall 2013 for the 510 and 710 and January 2014 for the 310.
Show starts tomorrow and I can talk to reps then.
Thanks for the info. Couple of questions if you don't mind ;-)
1) does the MRX 510 have the 7.1 or 5.1 pre-outs
2) have they changed the DAC/DSP chips from the initial MRX line --- if so, did they do it in house or are they using an off-the-shelf chip?
3) will the ARC software be able to be run on Apple devices?
Any info greatly appreciated.
post #15302 of 16455
Best if the specs handout literature on the new MRX series could be scanned & posted here.smile.gif
post #15303 of 16455
I think it is a big mistake to update these units with no HDMI 2.0 (if that is in fact the case). I would not update my main receiver (Onkyo 3009) without 2.0 at this point because it is very possible I might buy some UHDTV equipment in the next 2 or 3 years and will need 60 FPS (HZ) switching capability for sure.
I think this is why Onkyo has held up replacements for the 3010/5010 series.......logical if you want to supply your customer with the cutting edge equipment that you can use a few years.
post #15304 of 16455
Airplay for the new MRX line? Doesnt CEDIA show start today? wondering why there is no announcements
post #15305 of 16455
I think it actually starts on Thursday....Wed is like a media day.
Edited by JKR1963 - 9/25/13 at 6:35pm
post #15306 of 16455
Is there anyone that doesn't use an off-the-shelf chip?
post #15307 of 16455
Here's a picture of the back panel of the 510. The 710 looks identical, and so does the 310 except the pre-outs and amp outputs are 5.1 only. So, 510 and 710 have 7.1 pre-outs, but there is no pre-out for wide or height channels.
The show opens tomorrow at 9:00 mountain time. I will try to find out if ARC will run on Mac and ask about DAC/DSP chips. I will not be able to scan any literature, but I could try to take a picture.
On a side note, Martin Logan has a sound room nearby too, and I see some of their subs are able to be calibrated using PBK (ARC for the low end). They actually appear to be selling PBK kits under that name. I did not know that Anthem was licensing that technology for other companies. Interesting.
post #15308 of 16455
Do it comes with HDMI 2.0 or just the old HDMI 1.4?.
post #15309 of 16455
Thanks! I have the PBK kit for my two Paradigm Reference Seismic 110 subwoofers. Works great.
Cheers.
post #15310 of 16455
That rear panel shot has got me worried, it appears that support for either Heights/Wides has been dropped. The speaker terminals only have labelling for Rears, Bi-Amps, and Zone2. My fronts heights would become redundant???
Also, I thought the early release info mentioned support for two subwoofers???
Have to wait til the full info is released.
Regards, Mike.
post #15311 of 16455
2xhdmi outs for all x10 models ?
post #15312 of 16455
HDMI 1 4K 2K
post #15313 of 16455
Information is now on Anthems website for the new MRX line
http://www.anthemav.com
post #15314 of 16455
Looking at the pdf on Anthem's site it also says only the 510 and 710 can decode DTS-HD Master Audio. The 310 can only do DTS-HD High-Resolution Audio. So even if you only care about 5.1 that will rule the 310 out for a lot of people.
post #15315 of 16455
Probably a typing error/oversight. Worse case scenario is to let the Blu-Ray player send it LPCM data.
Cheers.
post #15316 of 16455
Cheers.
Very true the player could always do the decoding. not sure if it's an oversight or error though. They made sure they printed under decoding as "• DTS-HD Master Audio (MRX 710/510)" Looks like they meant to list it that way. I guess only time will tell.
post #15317 of 16455
Regards, Mike.
Unfortunately confirmed on avf in uk NO heights!!!!
Im sticking with my 300
post #15318 of 16455
I'm in the same boat. I've actually got 9.1 with heights, so I definitely can't do the new line without the pre-outs. It doesn't look like it has hdmi 2.0 either, unless I'm blind - which is unusual considering these will be the new line for a few years anyways. Oh well - guess it saves me money for not having to switch.
post #15319 of 16455
[quote name="AV_mike" url="/t/1289533/anthem-mrx-receivers-300-500-700-owners-thread-tweaking-guide/15300#post_23772811"]That rear panel shot has got me worried, it appears that support for either Heights/Wides has been dropped. The speaker terminals only have labelling for Rears, Bi-Amps, and Zone2. My fronts heights would become redundant???Also, I thought the early release info mentioned support for two subwoofers???Have to wait til the full info is released.Regards, Mike.[/quote]Unfortunately confirmed on avf in uk NO heights!!!!Im sticking with my 300
Unbelievable... And it is dts-hd master only on the 5/710!!???!!???
post #15320 of 16455
Originally Posted by Sean Spamilton View Post
[quote name="pixphipau" url="/t/1289533/anthem-mrx-receivers-300-500-700-owners-thread-tweaking-guide/15300#post_23773610"]Unfortunately confirmed on avf in uk NO heights!!!!Im sticking with my 300[/quote]I'm in the same boat. I've actually got 9.1 with heights, so I definitely can't do the new line without the pre-outs. It doesn't look like it has hdmi 2.0 either, unless I'm blind - which is unusual considering these will be the new line for a few years anyways. Oh well - guess it saves me money for not having to switch.
Me too!
post #15321 of 16455
According to Anthem's literature yes.
post #15322 of 16455
I would be surprised and disappointed if that's true. What modern AVR at even 1/3 the price cannot do that?
post #15323 of 16455
Yeah kind of cheesy having the cheapest receivers out there able to do it, but not an Anthem. It would clearly be Anthem's way of trying to get people to buy the 510 over the 310.
post #15324 of 16455
post #15325 of 16455
post #15326 of 16455
post #15327 of 16455
Originally Posted by emidalla View Post
How were you deceived? I'm not questioning if you were or not, I'm just wondering what you meant. You didn't go into any detail.
post #15328 of 16455
From what I understand there were specific things in the MRX x00 line that Anthem was unable to change with the DSP stuff that was out of their control. They did have the ability to fix this in the AVM and D2 pros so I figured that perhaps they learned from the initial release and the 2.0 version will allow them to fix any similar type issues.
Cheers.
post #15329 of 16455
Well, what can I say? I am a (happy) MRX500 owner and I expected more from the specs of these receivers... Sound, in the end, is all that matters, but I would have expected Anthem to make me want to update my gear. Up to now, I am more than happy to have an "old" MRX model
post #15330 of 16455
Awww shucks. Look at it this way: the 300 was an over achiever.
