Originally Posted by heavygen
Hooked up the MRX 500 tonight replacing an old Rotel RSX 1056. Everything was going great (connected Oppo BDP 93, DVR/Cable Box, and Xbox using the receiver to switch the sources using the HDMI out to the TV with no apparent problems). While configuring the last device (a Wii), the video went corrupt out of the receiver (garbled picture). I verified that it was not the TV by plugging the HDMI cable directly into the Oppo, which worked fine. Switching inputs did change the picture, but it was still messed-up regardless of the input used. I managed to use the receiver's display to restore the factory defaults, which did not fix the problem. Powered-down, unplugged, etc, and the problem still remains. Any suggestions on what to do next before returning it and getting my $$ back? Thanks.
Heavygen
Heavygen
Quick update. Anthem support recommended that I take the unit in for replacement. I took it in to the dealer, he hooked it up and verified the problem and replaced the unit. Replacement unit is set-up at home and everything is working great (Oppo BDP-93, DVR, Xbox, Wii, Squeezebox all connected). Zone 2 all set-up, which took awhile since I forgot to tell those channels to be zone 2 in the set-up) and ARC has been performed for movie listening. So far so good.
Heavygen
Try moving your centre channel to see if you can get rid of the dip at the room gain region. You can use quick measure to test this quickly. If it is close to a wall, move it out away from it and measure as you go. I had this same issue with my CC690 and most of that dip disappeared.
