I'm curious about the scale (200-5000) under those target frequencies. Does that mean it doesn't correct below 200Hz?
post #3241 of 14609
3/30/11 at 9:59pm
Beta Main Software for the 500 and 700 is being tweaked.
And Arc just makes it shine!!! The sound and Arc was what drew me to the anthem receiver so i dont know what i would have done if Arc wasn't there. All i can say is i'm glad its there!! Its like peanut butter and chocolate they just go together
Not what HDMI says. I always said pay attention to supported HDMI features not version number. The rules finally changed this year to my liking and even better, next year mere mention of verison number will be verboten. Our lit says "HDMI v1.4a with 3D support".
http://www.hdmi.org/manufacturer/tra..._logo_pub.aspx Effective as of January 1, 2012, all non-cable products cannot make any reference to HDMI version numbers. Until that time Adopters can use HDMI version numbers only when the feature or features associated with that HDMI version number is clearly specified. For instance, a manufacturer can describe a product as featuring "HDMI® v.1.4 with Audio Return Channel and HDMI Ethernet Channel," but may not describe a product as being "HDMI® v.1.4 compliant." |
Just got a MRX 300 and going to setup with ARC. However, had a couple questions before I get started:
1. Is there a guide or something to walk us through this other than the sparse manual? 2. I have a less than ideal seating arrangement for my room, but according to anthem I need to make the first measurement in the center listening position. Then measures 2 and 3 to the left and right of that position. Since I usually sit off to the side of the tv and speakers, do I measure where I sit or measure from the center of the room? I can't tell what I'm supposed to do here. 3. Do I turn off all eq on my sub? Basically try to level everything out to 0 before starting? Thanks! I'm anxious to get started! |
