So, in other words, it's really ARC that sways you to the MRX AVR's? Anything else in the Anthem to sway the purchase?
Excellent build quality, proven stellar amp section, and ARC's ability to make a really noticeable sonic diff in your room. Most of the other features at least equal to the competition.
John
I think you must be comparing the Yamaha RX-A3000 with the MRX700, not 300. The Yamaha's list price is a little less than the 700 but the 300 is close to half the price of the yamaha
Yamaha? Personally I would stay away from any brand you can find at best buy? But that's just me :-)
The MRX line would be well served if it was more available to more consumers at places like Best Buy...
Personally, I think Anthems dealer network stinks.... but that's just me.
I'm glad Anthem, Rotel, mac's, etc etc are not available at best buy. You can hardly get the sales people there to explain the entry level toys they're selling. On the other hand, aren't the yamaha known for their brightness?
I'm still in 2 minds - not sure which way to go - but thanks for replies.
No-one seems to have picked up my query in that review though please of the SNR test result ? which seemed much lower than the Onkyo 609 ? which doesn't make much sense ?
Hi,
I didn't answer it as I couldn't find on the review website any overview of their testing methodology which would explain how the tests were done etc. Ask them the question?
Macs are available at Best Buy. They are not available at all Best Buys; but, they are available at some. I have two Best Buy's near me. One carries Macs; but, the other one doesn't.
You're probably referring to magnolia audio which is owned by bestbuy. Yeah they do carry some decent stuff.
The speaker sounds just as clean with half a watt as it does with 200 watts assuming the amp is not causing audible distortion. Of course, it does not sound as loud with less power. The question is how loud do you need it to play? If you need 200 watts, use a 200 watt amplifier. The difference between 200 watts and 120 watts is 2.2 dB. Noticeable? Yes. Deal-breaking? That's entirely up to the individual.
On page 18 in the manual, it talks about calibration with a spl meter. Do I need to do that before ARC? I thought ARC does the calibration as well.......hmmmm Confused :-/
Okay I'm definitely gonna need help on this subject. What are the steps needed to get the mrx 700 ARC'd?
I have a 5.1 speaker set up. If someone could list the steps in detail or give me a link, I would greatly appreciate it.
"Skip bass management and level calibration if using ARC with all inputs"
What does that mean?
ARC does room correction which includes the bass management. In bass management you set crossovers and a correction curve on the low frequencies. ARC does all this. ARC will also set the volume trim levels for all speakers. Set the volume control on your sub at about 12 o'clock' This is usually good enough. Of course ARC has to be set to "on" for all the sources. If ARC is not on for a source then of course no correction (including bass management) for that source. Volume trim levels are set for all sources whether ARC is on or off.
Distance doesn't have to be set before running ARC.
There is TONS of HELP in the FAQ section of another Anthem Thread - HERE
Set the distance for the primary listening position. ARC does not set distance but distance is used for ARC or non ARC.
Now I'm confused? I thought ARC set distances when run.
So page 14 and 18 would apply if one does not run ARC, correct? This would be for manual config?
If using ARC (recommended) you do not need to do section 3.2 or 3.4 in the manual. You do need to do section 3.3 by using a tape measure and measure the distance from each speaker to the primary listening position. You can do this before or after ARC procedure it doesn't matter to ARC.
Okay so when I receive my brand spanking new mrx700, all I have to do is measure the distances for each speaker to the primary listening position and ARC does the rest right? I do nothing else, correct?
