Yes, what is your setup 5.1 or 7.1? How did you check if DTS MA is working correctly? I am not sure why I am having issues with dts ma with the Aix disc.
Originally Posted by Brian-HD
Yes, what is your setup 5.1 or 7.1? How did you check if DTS MA is working correctly? I am not sure why I am having issues with dts ma with the Aix disc. |
DTS-HD MA does "special" stuff when 7.1 tracks are decoded to 5.1. The AIX Channel ID track for 7.1 DTA-HD MA is intentionally authored to reveal that this is happening so that you can confirm it is only happening when it is supposed to.
AIX did this by deliberately building in a -40dB volume reduction when the 5.1 decoding is engaged. If the device doing the decoding is using the 5.1 decode for that 7.1 track then it will sound as if there is no audio unless you crank up the volume. The track should only be used for level balancing with a 7.1 decode. Set the player to HDMI LPCM output and it will do a 7.1 decode since the MRX accepts 7.1 LPCM input. The Anthem will then down mix that to 5.1 for your speakers. But since that is happening after the decode the special stuff, including the authored in volume reduction, won't happen. None of the above is a bug. --Bob |
Does MRX calculates distance of speakers to listener position? I remember reading that it is not supported. It is supported in Audyssey calibration and wonder why it is not supported.
I think 700 supports HD Radio. Is HD radio needs subscription? Does it need any antenna etc? How is the quality of HD radio compared with what I can hear from Napster? |
Do you have MRX 500 or 700? I am assuming that +10 db means 75db (At 0 reference level) +10 = 85 db max level that it can send to all speakers. |
(in fact I think -12 did bring a neighbor over, and my building is incredibly well sound proofed).
Subs should have a subsonic filter I believe.
