Originally Posted by romavictor
Yes the 225 could go higher but I keep at 12 o'clock because it's easier to place it there for accuracy sake. The integrated's volume knob has just a tiny dot that tells you where it is.
Maybe I should get the MCA 50 and sell the integrated? Does anyone know how the two compare for 2 channel audio? That's my only concern.
If you plan to keep this complex setup, I think it is time to buy your self a "silver paint pen" and add a dot somewhere up around 90%. The fact that you are cutting the level of the input by close to 50% is a big issue here.
But why not simply get rid of the external amp and see if the 700 can handle your speakers at the volume you plan to listen? Many people on here planned on using an external amp, usually with the 300 or 500, and have opted just to go with the MRX because they found there was no need for the external amp!
As Eric-t stated... not knowing how loud you play, one can never say for sure (do you like to make your neighbors deaf?). However considering that you are currently setting your Integrated 225 at 50% volume, the difference between what the 700 supplies naturally and what you are effectively getting out of your Integrated 225 by setting the volume at 50% are probably not that different! If you can simplify your setup, I think you will be a lot happier! One volume control, much easier ARC configuration to understand and troubleshoot, no additional concerns about things like the Tone Control settings on the Intetrated 225 messing with what you are trying to accomplish.
(I do hope when you are using your Integrated 225 with the MRX, including when you ran ARC, that the "Tone Defeat" switch was on... otherwise you could be creating all sorts of issues that ARC is trying to correct).
