Can I run ARC with longer cable lengths?
post #6121 of 14714
8/11/11 at 3:13am
). Each wall the speaker gets close to will "boost" the lower frequencies of the speaker. So currently your center is getting some boost from sitting on the floor. If you were to place your fronts on the floor, they would like wise get a similar boost... of course each wall you add boost more, so if you then took your mains (now hypothetically on the floor) and slid them back against the front wall, the boost would go up further... now slide them into a corner and again it would go up still even higher! as you know have essentially 3 "walls" all reflecting the bass.
so your insight helps a lot... From what you are suggesting ,there should be an option on the speakers to use the internal crossover with the main speaker wires from the MRX's front posts to both the mid/high section of the speakers and the low end(probably using bridge clips on the speaker?) or alternatively the speakers can be set up with the main section mid/high end running off of the Main speaker wires from the MRX and then you would disconnect the bridge clips and the low (sub) area of the speaker would then be set to use an internal amp and the LFE sub input? Is that correct?
I do not understand your central paragraph. Can you insert some sentence structure for me?
I recently got the 500 and I am loving it so far. The dealer did not have a 700 in stock. He told me to take the 500 home and use it for a month, but keep all the original packaging. If I decide I want to go to the 700, I can upgrade for the difference. I am enjoying the 500 a lot, but is the upgrade to the 700 worth it another $500
![]() I am guessing not, which is why I went with the 500. The store had the 300 setup and I choose it over the Pioneer SC-37 which is their current flagship. Just looking for some opinoins, thanks! |
