Have you contacted Anthem Support?
John
I just got my MRX-700. The firmware version it came with is v40.08.
When I go to the Anthem website there are a few different downloads available. ARC Software v3.0.2 MRX 700 Software Upgrade v50.12 (120 volt) MRX Multimedia Upgrade v1.1.0 Do I have to apply the updates in a particular order? What is multimedia upgrade? Does this need to go before v50.12? I have all my Paradigm speakers hooked up to the receiver. I have not done any setup yet. I am sending BluRay movie into the receiver via HDMI. When movie is playing the display on the receiver shows PCM 2.0. I don't hear any sub activity. I have a lot to learn about Anthem and ARC tool. Is there a quick setup I can do that will enable all my speakers. I just want to make sure all the speakers are working and connected. I will do detailed setup at a later time. Thanks |
Thank for the suggestions. I will try them. I probably didn't make it clear before but the problem is the same whether I try the Motorola DVR on HDMI1 or the Sony Blu-ray on HDMI2. The problem seems to occur when the HDMI out is connected to the TV. I did try looking at the TV manual and there is no refference to CEC or anything like it.
First install the Main firmware 50.12. Uncompress the file first.
Now install the Multi Media update 1.1.0 using a usb stick. Plug it into the front usb port and hit multimedia on the remote until you see usb. It will ask if you want to install the update, say YES. You have to uncompress the downloaded file first of course. Install ARC from the CD that came with your MRX. Then download the 3.0.2 version and install it over the cd version. You microphone files should be in the correct directory after this. How many speakers do you have? Use the Quick setup to designate the number of speakers. This should allow them to be recognized. If you have an odd number such as 3, then only by running ARC with 3 speakers selected, will they work. John |
