Originally Posted by hehateme
Hi:
I am new Anthem user and struggling to do basic things a receiver can do.
I haven't run arc yet because I am waiting for the keyspan adapter to arrive.
My firmware is 40.08 and I cannot update it due to lack of adapter.
I also have Anthem MCA-30 driving my LCR speakers.
LCR Speakers are Paradigm Studio 100's
Sub is Paradigm Sub 15
Rear and surrounds are Triad In/Wall Bronze
My current Blu Ray player is Panasonic DMP-BDP310 but my new Oppo 93 will be delivered today.
I have not been able to get any sound into the sub woofer.
First I found out that default settings in the Panasonic were to downgrade 2 channel PCM. I changed its setting to bitstream and Anthem receiver started showing Dolby 3/2 when I played Casino royale.
I don't hear any sound coming out of the sub woofer. It is plugged in and the cables are connected. I am using Sub W pre-out from the receiver and plugged into LFE in in the sub woofer.
I have tried doing a quick setup many times. I do this when I have a BluRay movie playing. First question I have to answer is something like HDMI/TV what should be the answer. I am using a Projector.
When I choose the subwoofer to Yes the receiver changes from BluRay to Tuner on its own.
I have 2 sets of wires running from the media closet to the sub woofer. I was thinking of switching wires to rule out bad prewiring.
Let me know if anyone has any suggestion to verify if my sub woofer works.
I have waited a very long time to finish the home theater so it is tough to not being to able to get even 7.1 working.
Hi:
I would like to point out that if you do have a serial port on your pc/laptop then you do not need the keyspan. My laptop has a serial port on the dock so that is what I use.
When did you order your Keyspan, that thing has got to be getting close
