Originally Posted by Bob Pariseau
Open your results file in the ARC Windows app so you can view the charts. There are several ways you can go at this point. One is to use the Windows key combo for Screen Capture Active Window (see Windows Help). This puts the visible portion of the window in the clipboard. Now you can paste that into, say Windows Paint (bundled with Windows) and Save As the result, choosing the JPEG file format to keep the file size small.
You can't view all the charts at once, so you capture the upper charts, scroll down and then capture the lower charts. If you have a separate Music configuration you do this again for those (select Music in ARC's View menu to see those charts). Then bring up your Targets window and capture that as well. The end of all this is 5 JPEG files on your PC which you can then upload to AVS as part of a post here using the Manage Attachements feature found below the box where you type in your post text. Use the Preview Post button to convince yourself it has all worked before you Submit Reply.
--Bob
--Bob
Ok guy's I will try to do a screen cap. FYI when this damn Dolby volume is off this thing kicks ass! It really fills the room with sound!
