Originally Posted by chemh0ser
Hello all, I was wondering if I could get some input on my graphs. My speaker levels were setup by ARC as follows:
Front Left: +2
Center: +2
Front Right: +1
Surround Right: +1
Surround Left: -1
Aux Right: -2
Aux Left: 0
Sub: -10
Also, in the targets, I took it upon myself to boost the room gain from 1.79... to 2.5. I also noticed that i get a fuller sound and more bass with dolby volume on. Shouldn't it be the other way around? Thanks for your help!
Front Left: +2
Center: +2
Front Right: +1
Surround Right: +1
Surround Left: -1
Aux Right: -2
Aux Left: 0
Sub: -10
Hi chemh0ser,
Adding Room Gain will make the bass sound fuller, potentially, so that makes sense.
Your Subs volume is up way to high! ARC is lowering its level by 10db. You should adjust your sub volume down. I'm guessing about 20-25% from where it is set now. Is it at 100% right now?
ARC has done a great job with your speakers, however your speakers are very unusual for what we typically see. None of them go below 150Hz and based on the steep decline, I'm guessing they may have a high pass filter in place. Are these cube speakers?
Currently your sub looks to be rolling off starting around 100Hz. This leaves a critical hole between 100Hz and 150Hz that your speakers do not cover.
Can you provide some more details about your speakers?
lol
lol)
