AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide
Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 270
post #8071 of 14714
Originally Posted by atabea View Post
Okay, after trying ther "quick measure
" trick" I was finally able to find a position that woould produce the 120 number. Man, my back is sore!!. Freaking sub (HSU Research) weighs a ton. Anyway, the sub is now situated along the side wall about five feet behind the seating area. Volume is set at 9 o'clock.
I am attaching my graphs for review. Tigger, can you tell me how to proceed with running the sub in "flat" mode?
atabea
Way to stick with it! But you learned how to use Quick Measure and how useful it can be... pretty cool tool on the whole!
I think Jayray and Bob both have you covered with instruction on how to set "Flat", if you think you are missing something, let us know and we can revise/expand on the directions for "Flat" setup a bit more.
Be sure to post up ALL of your graphs, Targets window and Speaker Calibration Numbers after you get done! For the graphs, make sure you take your screen shots AFTER you hit "Calculate" so that you have both the red and green lines.
I'm assuming your new level of 9 is below what you had before (if memory serves me, I think it was 10?). Hopefully all of your levels will land between -3 and +3 when you are done!
Congrats, I can't wait to see what it all looks like!
**** Oh, and of course, you need to re-run ARC for all of your speakers including the sub now that you have the sub in a new location (assuming you haven't already done that). I would make sure you put your A/V screen back up and in place before doing this final ARC run as it may have an influance on the higher frequencies that ARC sees and corrects. After you have re-run ARC, that is when you will set the targets window to use "Flat" and then re-calculate and upload. And of course make sure you save your final ARC calibration file... give a great name like "Final ARC Run with Sub in Back of room ****
post #8072 of 14714
Ha! Yea, each of my two custom subs weight in at about 125lbs as I recall!
I was thinking the other day that they couldn'y weight that much... but then I weighted my custom front speakers after I finished building them and they came in at close to 50lbs each... and they are about 1/3 to 1/2 the size of the subs and the subs are double walled 3/4" MDF... where my fronts are single walled 3/4" MDF with corner strips...
post #8073 of 14714
Atabea,
One last thought... if your read Bob's post a few posts up on multiple subs, there were a few tips that would make sense for you as well once you are finished...
With your sub now behind you, depending on which way it is facing, you may want to switch the polarity of the speaker. Also, you probably want to listen to some FM radio static... as Bob noted, listen carefully to the low end sound it is making and adjust the phase control on your sub till the low frequencies sound loudest. As Bob said, sneak up on it from both sides and then use the middle of the range you find sounds best!
Happy hunting!
post #8074 of 14714
Thanks Tigger, Bob, Jayray and shrike645, I am about to follow the above instructions and report back. Fingers crossed.
atabea
post #8075 of 14714
atabea
Don't forget to turn your sub down. I'm sure you'll like the end results.
post #8076 of 14714
At what point should I turn the sub doen, before uploading or after uploading? Also, when I ran Arc, the measurements were taken with the sub in its normal position (9 oclock). Do I still have to turn the sub down?
thanks
atabea
post #8077 of 14714
thanks
atabea
Turn it down before you measure again. ARC calculates the calibration during it's measure. I think you posted the calibration levels twice and both times it was too loud.
post #8078 of 14714
My speaker settings are now:
Front right +2db
Center +2db
Front Right +1db
surround right -1db
surround left -2
sub -3
My charts are also attached. Everything looks to be within normal parameters. Hopefully this is it!!
atabea
post #8079 of 14714
Front right +2db
Center +2db
Front Right +1db
surround right -1db
surround left -2
sub -3
atabea
Can't see the fronts but it all looks good.
post #8080 of 14714
When I did my last measurements I left it at 9oclock and I got the results in the charts. Not sure, but it might have something to do with the final location of the sub that did not require me to turn it down to get the outcome. However, do you think I should turn it down and run Arc again.
thanks
atabea
post #8081 of 14714
here are the fronts.
post #8082 of 14714
thanks
atabea
They look very good now. Upload and listen. It should sound great
John
post #8083 of 14714
thanks
atabea
If it's still in the -9 to -10 range it should be turned down but I guess I would only do that if you were going to measure again. I don't think I'd make another run just to do that.
post #8084 of 14714
Hi, this is my first ARC.
Any tips?
post #8085 of 14714
Any tips?
Not too bad. Your fronts need a little work. It looks Like they are a bit close to the walls. Especially the left. The dip they both have near 200hz isn't fully corrected in the right. If you can move them a bit and get the chart on the low end down a bit and get rid of that dip I think you'll find that ARC will move the crossover lower.
Your sub looks like it could go to flat in the advanced mode. We've talked of the settings for that a few posts up.
post #8086 of 14714
Thanks, you're right, the front left is near a corner, difficult to move from that.
I will read your posts.
The subwoofer is not in flat. The peak betwen 20 - 30 htz, must/can be corrected?
One more thing: to my ears it seems a little flat sound.
post #8087 of 14714
Based on the measured charts it looks like you might have got used to more bottom end than a corrected curve. The fronts aren't too bad but moving them even a few inches might get rid of that dip and help ARC to lower the crossover which would help you with the flat sound.
Do you have room to move the sub? I would guess again that the rise between 20-30 hz in boundary gain from being in a corner.
Quick measure for both the fronts and the sub would really help you even if you are only able to move them a few inches.
When you have the best you can do with ARC give it a listen for a week or so to get used to a corrected room. There are some options like boosting room gain if you feel it still sounds flat. ARC has set your room gain at it's max but it can be changed manually, recalculated and uploaded.
post #8088 of 14714
Front right +2db
Center +2db
Front Right +1db
surround right -1db
surround left -2
sub -3
atabea
Atabea,
Things look really good now! Levels are exactly where we would like to see them between -3 to +3.
Speakers look good as well given the space you have to work with. ARC is managing them well and correcting for most anything we can't fix with location limitations.
I would sit back and enjoy!
The one thing you may still want to do, is to adjust the phase of the sub. You would do this by sitting in your primary listening position, listening to radio static between stations... then have someone turn the phase knob from clockwise to counter clockwise all the way and then back... have then note where on the dial you are telling them it sounds "loudest". Note you only want to concentrate on the low end of the static.
As they go from one extreem to the other, the person turning the knob will probably find there is a range you like. If that is the case, just pick the center of the range!
post #8089 of 14714
thanks
atabea
Your latest Calibration levels look great, no need to change anything (assuming that the level of the sub is set where you had it when you ran ARC).
post #8090 of 14714
+1 Shrike645 is steering you in a good direction I think.
If you can, try to get your fronts further away from the corners they are in... try about 2' from any walls if possible.
And as to flat, again, I have to agree, I think you may be used to some really inflated bass... give your current settings a try for a week or two of solid listening and I think you will find that you are hearing much better detail in the low end and you will find it is not that flat, after all, once you get a bit more used to it
post #8091 of 14714
What did ARC set your Speaker Calibration Levels to? I'm betting your sub has a negative number... I have a feeling that it has probably been running to loud as well...
Please post up your Speaker Calibration Levels.
post #8092 of 14714
Again you are right, the sub is in a corner (difficult to move but will try).
which leaves me puzzled is the fact that moving the front speakers randomly up to 25" (could not leave them there) doesn't make big changes. The 200htz dip is almost the same, maybe a speaker issue/attribute?.
Thanks for your patience Shrike645, mine starts to fade because the reason to buy the Anthem was just try to improve the acoustic.
post #8093 of 14714
Something with the fronts is making ARC set the crossover/cutoff at 100 and it looks like they measure better and should go lower like 60 or 80. I'd rather see that changed by moving but it could be forced in the target window, recalculate and upload. I never like to recommend overriding ARC for this. It's the very very very last thing I would try. I don't mind changing the room gain value if a user feels it needs it.
post #8094 of 14714
Hi Tigger!,
I hope you are right and with time I listen better sound.
I'm uploading (I was playing with quick measure), then I will post the levels.
Any other thing to post you?
post #8095 of 14714
Here we go:
Dolby Volume Leveler: OFF
Dolby offset: 0
L +2
c +3
R -3
SL +3
SR +3
SB -9 !!!!
post #8096 of 14714
Here we go:
Dolby offset: 0
L +2
c +3
R -3
SL +3
SR +3
SB -9 !!!!
Yup sub is way too loud. Happens a lot around here.
post #8097 of 14714
Yes, I can see, but if the A/V has headroom up to -12, what is the problem?.
excuse my ignorance, I am new to these topics and try to understand everything you say me.
post #8098 of 14714
You are pushing 12db (sub -9 and surrounds, center +3 = 12 db). It is my opinion that the trim or boost to speaker calibration does not use any resources but there has been some discussion on that and I haven't seen any definitive agreement. That aside I'm a little detail oriented and if I were do a measurement again I would turn down the sub to get the calibration levels +-3db.
How is it sounding?
post #8099 of 14714
How is it sounding?
OK.
I'm going to measure now. Before starting another doubts:
-is interesanting mark the "same as movie" option? (I use it more for music than movies)
-any recomended change in the target tab?
Thanks one more time.
post #8100 of 14714
OK.
You can measure with the "same as movie" checked and then if you want you can remove speakers in the music option such as the center and surrounds and recalculate. You can assign the music or movie mode to each source or source overlay.
I wouldn't want to change anything in the target until we see the set of charts you are measuring now. If we do need to change the targets you don't have to remeasure, just change the value, recalculate and upload.
