AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide
Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 327
post #9781 of 14613
Originally Posted by Tigger! View Post
8) Optional: You may want to hit the 'Advanced' button down under your "Advanced Settings" section and set your "Subwoofer High Pass Order" to "Flat" as it looks to be very capable below 20Hz. This is typically recommended only for subs that have low end protection and are capable below 20Hz.
When playing with Targets I have noticed that there are choices other than 'Auto' and 'Flat'. For example, a 3rd order filter would give you sub-20Hz protection but extend the flat region below 30Hz because it is fairly steep compared to the 'Auto' curve. This may be a compromise between 'Auto' and 'Flat'.
*Note: we are assuming that your seating postitions for both Music and Movies are the same. If they are different, then you would want to re-run ARC and select the option to do seperate Movie and Music Profiles. This will then run through two sets of microphone readings... one set for each profile and the unique seating locations of each profile.
I always wondered - what situation would warrant separating Movie and Music Profiles? For example, I run 5.1 system for Movies, but for Music, I run my B&W 805s speakers full range and turn off all other speakers. However, I use the same 5 measurements I use for Movie profile. What would I do differently if I were to measure separately for 2-channel music?
post #9782 of 14613
Someone with a screen may have the screen raised for 2 channel music which would require a separate set of measurements for music mode.
post #9783 of 14613
Where are people buying these receivers in Dallas area? I'm in the market for a decent receiver that has very good room eq function, and anthem is highly recommended.
post #9784 of 14613
The issues you are describing are not familiar and we have worked through a number of interesting issues on this forum. I would talk with Anthem Support ASAP.
Also see if your dealer has a floor model or other unit you can try. It sounds like you may have issues specific to your MRX, not the MRX's in general. If you are going to play with different firmware releases, you might try v50.12. It has been the most stable (v50.19 is known to have issues).
I'm very concerned about the codec "dropping" in the middle of a show (i.e. not during a commercial break or when skipping). I'm also concerned that you state your HDMI connection is causing distortion to the picture. HDMI is digital, so their should be no distortion... perhaps digital noise or other issues such as picture droping out, those issues would be caused by poor signal quality and errors, but distortion is highly unlikely. Distortion is really more an analog issue. You are going from your Tivo to the MRX via HDMI and then from your MRX to the TV via HDMI, are you not?
Hey, we'll see. I really want this to work. It's a great unit. Great SQ, good feature set, build quality, etc. I don't know if there's really anything else out there like it. Maybe I just got "one of those". It happens.
post #9785 of 14613
Hi Dan, small world in deed, I bought my MRX from Ensemble... and I likely drive by your old office everyday on my way to work in Burlington, MA.
On to your current question... .
Hopefully Ensemble is alive and well, bought my first Pioneer Elite RPTV from them, as well as all my Meridian gear. That's also where I first heard Aerial speakers, including the CC5 and I've been lusting after an Aerial setup ever since...
Stereo Design in SD reminds me a lot of Ensemble, good guys.
In Nashua, I worked at 1Tara Blvd, just in front of the Radisson. I also used to live in Burlington, when I worked in Billerica off Concord Rd (Wellfleet Communications/Bay Networks/Nortel).
Back to Anthem talk...
I'll follow your advice on experimenting with different targets, your guidance makes sense to me.
I have to say that I'm very impressed with the MRX-300 performance so far! In all seriousness, I think it's the best sound I've ever achieved. Really staggering to me. It's surprising to me how well the baby MRX drives my B&W's, almost makes me think I don't need an external amp, though I will probably still opt to go that way. It just won't be an urgent need.
I'll post some updated charts later this evening.
Dan
post #9786 of 14613
My power cord is short to get to the dedicated outlet I have. I am using an extension cord. Anyone has any susggestion about a good quality power cord for MRX700.
Much appreciated.
post #9787 of 14613
I purchased mine from HOME THEATER GALLERY in Carrollton and had a very good experience.
You can also get them from KELLUM AUDIO/VIDEO & APPLIANCE on Cole Avenue and in Fort Worth at Marvin Electronics.
Go to http://www.anthemav.com/where-to-buy/where-to-buy for more info.
(I also highly recommend the MRX.)
post #9788 of 14613
Based on the helpful advice from Tigger! I've gone back through ARC and played around a bit more with different targets and different setups for Movie and Music.
For the Movie config, I used Auto Detect to allow ARC to select all of the settings and the only change I made was in the Advanced Menu where I set the subwoofer to Flat.
For the Music config, I turned off all speakers except for the Front L/R and set the frequency target to 30Hz.
Levels remained as before: 0 / +2 / 0 / -2 / -1 / +1
Updated screen captures attached, including the graphs for the Music setup.
Dan
post #9789 of 14613
Yes, you could use a few of the non auto options as well. However I will be the first to admit I can't advise much on those settings.
Another example... perhaps your room has a couch center stage where you and everyone else gather for watching movies. However you also have a comfy chair off in a different different part of the room where you listen to music.
In this example you would stage the mics around your couch for the movie profile (and or what ever listening you do on the couch... the title "Movie" profile really has no meaning except a common use for it). Then for the second set of sweeps, the "Music" profile sweeps, you would stage the mics around your comfy chair.
This of course would help to provide the best listening experience at those two location for each of your activities.
Edit: Shrike645 makes a good point... so I've expanded on the concept a bit to give another/better example of a use for two profiles and mic readings... see post http://www.avsforum.com/avs-vb/showt...0#post21805750
post #9790 of 14613
Another example... perhaps your room has a couch center stage where you and anyone elses gather for watching movies. However you also have a comfy chair off in a different different part of the room where you listen to music.
This second example is correct but of course the speaker distances will be incorrect. ARC also uses the first mic position for volume trims and again there is only the one set of these.
post #9791 of 14613
Good points to keep in mind...
Of course if you are only running stereo, the distances may not be as big of a concern (the chair, if it is off to one side, may be a concern to your sounds stage however )
Building on the same idea, but without concern for the distances would be that you have a couple of rows of seating or a wide seating area that you needed to cover for your theater watching, however when listening to music, you only sit in a single seat in the front row by yourself late at night
In this case the distances will be spot on, but the mic positions can be arranged to provide the best experience under the two different listening conditions... a large area with decent sound everywhere or a focused single seating area with excellent sound.
post #9792 of 14613
Much appreciated.
Any high amperage extension cord (such as say the ones sold for appliances that draw a lot of current) should work fine. No need to spend a lot of money on fancy power cords... After all, the wires in your wall aren't that fancy
post #9793 of 14613
Dan
Can't wait to hear how it all goes!
post #9794 of 14613
Dan
Dan,
This looks like a much more traditional setup... if you want a bit more flexability, you can keep your other speakers, such as the center and surrounds, enabled for the Music Profile as well. Then you can listen to multi channel music, or use the AnthemLogic surround modes with your stereo sources if you like, as well as listen in traditional stereo!
"But I want a true 2.0 stereo sound from my Music Profile" you might say... no problem. Just setup the 'Listening Mode Presets for "2.0" source to be 'Stereo' and just your front L/R speakers will play when you play stereo sources. Wait, you want create a surround sound from your stereo source but keep the stereo imaging without having the center channel play... no problem, set your "2.0" source selection to 'Anthem Logic-Music' and the MRX will take your stereo source and create surround sound for you without using the center channel!
post #9795 of 14613
Thanks Tigger.
post #9796 of 14613
So remember I loaded 50.22 to my 700 and I thought the "center channel" in my headphones moved to the right a little.
So I re-loaded 50.19 and it didn't change it back.
So I'm thinking am I nuts?
Was it always that way?
But i used my headphones on my computer and it was fine, so it's gotta be the receiver.
SO I decided to reset the receiver, which was 50.19 anyway, and boom - voices are back in the middle again. I'm still not sure what happened.
With Dolby headphone I don't think you can just move the "balance" control -- there isn't one. Plus, unlike an old fashioned receiver that just pumps headphones out as stereo 2 channel, I assume DH actually uses the five channels and downscales it to 2 but uses technology to give some illusion of five. At least, that's what it's supposed to do. So IMO the update (50.22) somewhere along the way, moved that "center channel" over to the right a notch or two in dolby headphone. The basic left/right channel seemed balanced to me.
I did loose the better codec holds during TiVo skips again with 50.19.
Seems like a win one loose one. I'll contact Anthem tomorrow, maybe they can fix it before they release 50.22 or I can manually get around it.
post #9797 of 14613
If you experienced the same off center issue with 50.19 before the reset, I would re-loand 50.22 and see if the issue is now gone. I'm guessing you never tried a reset with 50.22?
Resets are a pain, so most of us try to avoid them when doing an upgrade, however... they should always be attempted if things seem off, before assuming the upgrade was the issue.
If 50.22 does seem to still exhibit the issue, make sure you contact Anthem and let them know what you are experincing... then request v50.12. The changes in v50.19 are likely not anything you need and you will find the pop in 50.12 similar to 50.22 I believe.
post #9798 of 14613
Just wondering if there is any Anthem Dock update yet? What's taking so long??
Also, with the popilarity of dual sub set ups, and the fact that Audyssey XT32 does it now, when is Anthem's Arc going to be able to set up 2 subs in 1 system independently?
post #9799 of 14613
Hey everyone!
First time writer, long time reader Excuse me for my grammar - english is not my native..
Anyway, I am now the happy owner of an MRX 700 and what a friggin amp! I am addicted! I used to run a NAD T747 on a NAD T955 power amp, and there really is no reason to compare the two.. The Anthem is from another planet - worth every penny. On the speaker front I am in the process of converting to the MKSound 950 THX package - im still missing the sub and sides/surrounds.. Place holders are the surrounds from the MK 750 set and a B&W sub from the good looking CM series. Yes - 5.1
As most folk are, im kinda overwhelmed by the ARC and the ammount of information there is to "grasp".. So, I hope can borrow some of your expertise
These are my levels according to ARC:
Front left -1
center -2
Front right -1
Sur right +3
Sur left +3
Sub 0
Crossover 80 Hz on all of em.. Which brings me to another question.. THX speakers are designed to roll off at 80 HZ as I understand it(?) .. Shouldent I be aiming for 80 Hz in this case? You see, my first ARC cal was a "quick" one, and that wanted me to go for 100 Hz on center and 120 Hz on the Surrounds.. I listend to that for a while, and changed it to 80 Hz - felt it as an improvement.. A thicker more blended sound..
This beeing my first post ever on AVS, I really hope my charts are attached!
Anyway, thanks for a great read.. I still got a long way to go, but I'll get there.
Thanks in advance.
post #9800 of 14613
Originally Posted by Therien View Post
Hey everyone!
Front left -1
center -2
Front right -1
Sur right +3
Sur left +3
Sub 0
Thanks in advance.
Welcome Therien!
Your english seems excellent, no worries! It is up to the job and at least equal to many of us on here (I for one am a terrible speller ).
Looking at your levels, they look excellent.
Looking at you graphs, I can see why ARC set your cutoffs a bit higher. Your center and left surround appear to be struggling at the lower end. ARC has attempted to fill the holes down there but can't quite do it. This is why it is opting for a higher cutoff. If you can perhaps reposition the left surround closer to a wall, you may pickup some boundary gain that will help fill in the lower end. In fact your fronts would also benefit from a little boundary gain, particularly the front Left (are your lefts further from the walls than your right speakers)? If you can move your speakers a little closer to a wall, the boundary gain may help fill in the low end for you.
Looking at your sub, it looks very capable, however in its current location it appears to a bit wild. It also may have a filter or two still engaged. If possible, set your low pass filter to bypass or as high as it will go (probably like 180Hz). If there is a high pass filter, it also should be set to bypass or as low as it will go (possibly something like 20Hz or 15Hz?).
I would use "Quick Measure" in ARC to try moving your sub and seeing if you can get the response to flatten out and extend a big higher. For a picture of a really nice flat sub, see Jayrays graph in the FAQ post at the start of the thread (link in my signature as well).
Let us know what moving the main speakers does and how you succeed with the sub. Post up your charts as you are playing if you want us to provide some feedback. Also post up your targets window for us.
post #9801 of 14613
Well, I figured out the weird headphone deal. When you have different front speaker distances it screws up dolby headphone and moves the "center channel/voices" around, adds echo, etc. So if all your front speakers are set to 12 ft and you change the front left to 11 ft in moves the center channel/voices to the left; if you change front left to 13 it moves center channel/voices to the right. Obviously, since your head is in the middle of the headphones speaker distances should be dropped from the equation.
I sent Anthem this and my TiVo/codec right channel squeal/whistle and got a new 50.23 update link which didn't help.
I'm currently woking with Anthem on the Speaker distance/headphone deal over E-mail they were unaware of it.
But I have more pressing issues now. I've got growing hiss out every channel and a gurgling hiss out the left rear surround channel. If I swap speakers the gurgle moves with it, TiVo, Oppo, playing or paused, TV off......tried it all.
Plus, some in and out buzz noises from the receiver rear as well. Dealer wants it out of here to avoid damage. So, I guess I'm out of HERE until I get a new one.
Thanks for the help Tigger! I hope to have better posts with ARC charts and such next time.
post #9802 of 14613
Hi Dean,
Nice work on the Headphone diagnostic! Sounds like a real bug for sure! Not to many people use headphones (though I know a few on here have, I'm guessing they had equal distances?). I'm sure Anthem will sort that one out real fast.
As for the hisses and buzzes, that sounds real bad... I'm pretty sure that is not a firmware issue, that sounds like a sick Amp... I think when you get your replacement it is going to be a whole new experience!
One question, when you said the hiss followed when you moved the speakers... did you mean the his stayed on the same channel even though you moved the speaker... or did the hiss move with the speaker to the new channel? I'm assuming you meant the first as that points to the Amp... the second would seem more like a speaker issue. I assume you have checked both ends of all of your speaker wires to make sure there isn't a single wire shorting something somewhere or something like that?
Have you taken the Amp to your dealer and tried it there?
Let us know how things are going! I think a new Amp is in order and you will be very happy
post #9803 of 14613
If you read my previous posts in this thread you will see I have done a lot of testing with different AVRs in my home over the last several months. By far, the MRX 300 I have had for about a month now, sounds worlds better than everything else I tested. However.....
I have read a few posts where people have been experiencing frame drops when the AVR is set to anything other than "through" mode. Is this something that is inherent with the video chip-set in these systems? Does anyone know any way to mitigate it outside of bypassing it completely?
I have a 60inch Panasonic ST30 and I would prefer to use the 1080p up-scaling since overall it looks much better than 1080i on a screen this large. The frame skips are rather noticeable but something I can live with. I did not notice this on any of the other AVRs I played with including several H/K models and several Onkyo models.
Running p50st30
DTV HDDVR
MRX 300
Thanks for any insight you can offer.
post #9804 of 14613
Welcome Therien!
Hey Tigger
Your response comepletely blew me away! All I got is "WOW"!
Yes you are absolutely right. My left speakers are futher from the wall. I've attached a crude "paint" of my room (The scale is somewhat off..) - the room you just described It's gonna be pretty hard moving the rear left, as it is mounted in the wall.. Allso im moving in a few months to a much more suitable room - tbh i can't be bothered at this point But I will definatly try to find a new spot for the sub - which you say is a tad wild, which it is.. I have had alot of trouble locating it, I placed it where I could here it the most - though this was before ARC.. I will try pushing it into the corner and moving the right front away from the wall..
About the sub.. I am positive that it is set to bypass.. Hmm, feel like a noob..
Thanks for the awesome feedback, I will now go work with your suggestions! I'll post some new graphs when this is done, hopefully I can get that sub under control.
Cheers!
post #9805 of 14613
I have some pics of the current spot my subwoofer is in and my current ARC graphs. I'am having trouble fine tuning sub placement. I can't seem to get a smoother graph using quick measure. I was hoping someone could give me some tips in case I didn't think of it in different placement spots. The sub is currently 9" from the wall. I changed my target curve for subwoofer from 80Hz to 100Hz but the graph looked worse so I went back to default of 80Hz.
post #9806 of 14613
I think you will find that you have it too close to the wall/corner. the large peak in the low end is boundary gain from the corner. If you can lower that by moving it out along a wall then the overall curve will flatten out and I'm sure it will get the cutoff closer to the ideal 120.
post #9807 of 14613
The sub is 36" from the front wall of the room. In the pic you can see my radiator cover, I have 6" left to move the sub down that wall. Do you think moving it out farther from wall in current pic would help?
post #9808 of 14613
Are you locked into that one spot for placement? If not, then I would experiment with placement in your room and find the sweet spot..
post #9809 of 14613
Hey Tigger
Cheers!
No problem, I've looked at a few of these ARC graphs before lol.
I wouldn't worry about trying to match your right speaker to what the left is doing... the left being worse than the right, I'd just let ARC do its best to correct everything it can with the left. That having been said, I would probably keep the higher cutoffs it suggested. I think once the sub is in a better location, the higher cutoffs will sound just as good (if not better) than what you have now.
As for the sub, these are always fun to deal with (sarcasm there). The best tool you have is "Quick Measure" in ARC. This will let you move the sub and watch the graphs of the sub in real time. Don't worry if you lose a few db, if we need to get more db's we can increase your subs level control... or if need be let the MRX increase the line level a bit. Focus more on trying to get that big spike to settle down and to get the higher frequencies (60-80Hz to 140Hz) to maintain a bit better the same height as the lower frequencies. If this means you need to lose some bondary gain and get the lower frequencies to settle down to where the higher frequencies are, that will work as well.
Our goal is to have ARC NATURALLY set your cutoff on the sub up around 120Hz.
Good luck and happy playing! Of course once you are done playing, you will want to re-run ARC and upload your new results. And post up here so we can take a look.
post #9810 of 14613
98% of the time, you really cant force the sub to go any higher than what ARC pics... there are exceptions, but I don't think what we are seeing is one of them We really need to find a place in the room where the sub is happy and naturally hits 120, which this sub looks very capable of doing.
+1 Oh, yea
I would try moving it out from the side wall, the wall that is next to the radiator. Don't worry about blocking your front speaker (I think)... if the shadows in the grill cloth of your speaker are correct, your speakers are all up much higher in that speaker cabinet and the grill cloth is only covering the front of the cabinet down below. Of course if there is a port down at the bottom of that cabinet, make sure you leave it at least 6-8 inches of breathing room for the port.
I'd try and get the speaker at least 12-16 inches off of that side wall.
You can also play with quick measure and see if simply rotating the sub 45 or 90 degrees makes a difference.
This is of course also a great thought... is there another location in the room you can try the sub.
