Originally Posted by Tigger!
NOTE: I had a copy/paste typo... the second part of your highlight should be "Min Subwoofer EQ Freq"... I already fixed my first post, sorry for the confusion.
Yes the "High Pass Frequency" & "Min Subwoofer EQ Freq" apply to the sub. These are set in the "Advanced" menu of the "Targets" window for the sub in ARC.
We never changes those values, so you won't see them mentioned much in this thread. If your sub has the "Subwoofer High Pass Order" set to 'Auto' you can't make any changes to them anyways.
If you set the "Subwoofer High Pass Order" to 'Flat, then you can change the "Min Subwoofer EQ Freq" only (lowest excepted value is 20). If you pick a manual High Pass Order you can change both values, both have an exceptable input range or 20 to 80 I believe.
I never ventured into the advance setup for the sub so the "High Pass Order" words through me off. I was thinking "High Pass Filter".
The only change I had done was manually setting my sub cutoff to 120hz from 80hz. Looks like I may need to make the adjustment within my MRX as well.
