AVS › AVS Forum › Audio › Speakers › SVS SB02 vs Infinity Primus 162 vs Polk Monitor 40
post #1 of 7
I am looking for a setup for my in-laws basement. Sub I am planning on a Epik Legend or Lava LSP12
Receiver Onkyo 608
Speaker wise looking at
4 SVS SB02 and a SCS02
or
2 Polk Monitor 40, 2 Monitor 30 and a CS2
or
4 Infinity Primus P162 and a Primus Center
They are not audiophiles or anything, just want some good sound at a good price. But for me I want something decent when I go there as well. Basement is probably 20x35x8 sealed. Total 5.0 speaker budget is $700 or less if there are any other ideas.
Any Thoughts??
post #2 of 7
Go for the Primus, and make sure you get the c350 center. The Primus speakers will have more output, which is important for your large room, and the Primus c350 center would likely be the best center in that bunch. Those are great speakers. If you want to save a little bit of money you could go with primus p152 for the rears, you wouldn't really be losing anything back there but I would definitely go with the p162's for the fronts.
post #3 of 7
I can;t seem to find the C350 center anywhere, but also hoping that won't push it over budget for them.
post #4 of 7
http://www.amazon.com/Infinity-Primu.../dp/B000M687JI
post #5 of 7
Also wondering if I went for the Polks if I could use the CS2 center with the dual 6.5s instead of the cs1 with dual 5.5s, or if the gains would be minimal or problematic with the other speakers having 5.5's, thinking maybe it would have bigger sound for dialogue.
post #6 of 7
Any of the monitor speakers pair well, so CS1 or CS2 will both sound good. Of the two CS2 is the better speaker so if you can swing it go for it....
I would go with the SVS speakers myself since they have a really good bang for the buck and are a great company!
post #7 of 7
The CS2 is on sale at NewEgg. Great Price. I got the Monitor 60's series 2 and the CS2 today.
edit. WHOOPS, sale ends tonight... sorry I didn't post sooner for ya.
  Back to Forum: Speakers
