Originally Posted by WiWavelength
A fully differential design will cancel common mode noise & distortion. Translation: it may have a quieter noise floor and lower harmonic distortion.
Your B&K is not a differential design. You will not likely find a differential amp section in an AVR. And the positive qualities that you ascribe to your B&K are those of almost any accurate amp.
The comparison to the Anthem amp was probably a misleading one unless you made it in the same room & speakers as your B&K. "Congestion" sounds like a product of speakers & acoustics, not amps.
AJ
AJ
Just to be clear (because i am not 100% sure myself), differential means that its internally bridges. So the balanced incoming signal the pos and neg are amped and send in that way to the speakers correct ? So any amp that you can bridge can be differentially used. How well that works depends on the amp's in question since the effect is 1/2 the load (that has effect on snr) and possibly 4x the power coming out.
If fully balanced means, bridged amps (please explain to me if it isn't the same) than yes you will loose any external effects on the signal but you gain possible nasty's as a effect of having them bridged.
Daniel.
PS: i use my 10 channel amp bridged.
