AVS › AVS Forum › Audio › Speakers › **Official Ascend Acoustics Tower Thread**
**Official Ascend Acoustics Tower Thread** - Page 37
post #1081 of 1437
Originally Posted by Ryder125 View Post
Say I wanted the tower in white would they do that? Is there much of an extra cost for this.
Hi Ryder125,
We would be happy to do this for you smile.gif We have a large batch of tower cabinets currently under construction so it would be best to discuss this option quickly so that we can custom finish the pair for you before they get finished in one of our standard finishes.
Please give us a call or email if you are still interested.
post #1082 of 1437
Long-time lurker here. First, many thanks to all the thread regulars for your in-depth help on this thread. I'm in the market for a 2.0 tower speaker setup (100% music) and I'm really intrigued by these Ascend Towers. I currently have a Denon 2112 AVR [90W/per channel (8-6 Ohm)] and would like to use the zone 2 channels for these towers in a separate listening room. Speaker cable run for this zone 2 would be at least 60-70'. Would I be able to drive these towers in my current situation or would I be better off with a dedicated amp?
Cheers,
J
post #1083 of 1437
Cheers,
J
Just by way of example, I am running 2 Ascend 340's as surrounds with a 60' run of 14ga. cable up one wall, thru the attic and down another wall. I used one twisted pair per binding post so combined it's ~11ga. They are powered by an Onkyo TX-NR809 and I have no issues with driving them. They are less efficient than the Towers so the same run to Towers should be perfectly fine.
Sheep
post #1084 of 1437
Cheers,
J
HI Jmac,
The Sierra Towers have good efficiency and 90 watts of power is more than enough to drive them to any listening level you would desire. 60 - 70' of cable is also not a problem but I would recommend that the cable be at least 12 - 14 gauge to keep added resistance down (this would be the same for any speakers)
My only concern with the Denon is if you plan to use the Zone 2 at the same time whn running your main 5.1 setup. Doing this might cause a lot of strain on your receiver's power supply (I doubt this unit has a separate power supply for zone 2) and thus the rated power will actually drop for all the channels. If you don't plan on using zone 2 at the same time as zone 1, you will not have any issues at all.
Hope this helps!
post #1085 of 1437
Dave,
Thank you very much for the reply. This answers all my questions. I can't see a situation where I'll be running both zones at the same time (especially now knowing it could overload the Denon). Now come the difficult, er, fun choices (finish, RAAL) wink.gif
post #1086 of 1437
I don't see the sierra tower center (horizon?) on the website. Does anyone know the dimensions? (Are they published?)
post #1087 of 1437
11" high x 23" wide x 12.5" deep (13" deep with grille)
post #1088 of 1437
post #1089 of 1437
post #1090 of 1437
Originally Posted by JustaSheep View Post
There's a also a custom sized center:
http://forum.ascendacoustics.com/showpost.php?p=40484&postcount=974
That is only one of the custom centers. Dave will make several different ones depending on what you need.
post #1091 of 1437
Of... course restrictions would apply keeping it to a minium of 8" in height x 26" in width...like he stated over at the ascend forum the depth is more flexible.
post #1092 of 1437
Well it's official, the Ascend Acoustic Sierra Towers with RAAL are now on my list. Can someone here tell me the crossover points for the drivers? Also can someone provide me detailed specs of the mid and low frequency drivers? I believe these are good drivers (name escapes me ATM). How do they compare with the drivers offered in the SALK SCST and the PSB Imagine T2's?
These will be used for HT and 2 channel music (or 2.1). I want the priority to be on music reproduction, it will likely see as much or more HT use with the wife but when I'm listening to my 2 CH stuff I want it to sound good. I'm coming from the SWAN DIVA 5.1's as my mains and their C3 center. So I'll swap out the frontal arrangement and cross over my SVS PB12/NSD somewhere between 40 and 80hz depending on the speakers/room.
Edited by 6SpeedTA95 - 11/3/12 at 9:15am
post #1093 of 1437
The drivers are proprietary to Ascend....they are not off the shelf.
For the crossover points, I don't recall if Dave ever mentioned them. Might be best to give them a call and ask.
post #1094 of 1437
They are proprietary but I thought it was a fairly well known and respected company mfg'ing them?
post #1095 of 1437
That is for the soft dome tweeter, which is manufactured by SEAS for Ascend.
Edited by cschang - 11/3/12 at 1:21pm
post #1096 of 1437
Hey guys....
I'm thinking about switching my front stage to Ascend CMT-340s. Currently using Polk M60 and CS2 center. After two years my ears have had enough of these cheap Polks. I'm looking for a more laid back and full sound which I read the CMT-340s would fit the bill. I wanted CHT sho-10s, but the wife is complaining how ugly they would look but approved the Ascends. Has anyone heard both Polk monitors and Ascends? I'm not wanting to make another lateral move but rather an upgrade. Just wanted a little reassurance before pulling the trigger on some B-stock Ascends. biggrin.gif
Or if anyone is thinking about selling their CMT-340s, let me know.
Edited by cyde01 - 11/4/12 at 6:22pm
post #1097 of 1437
No black friday deals for Ascend frown.gif?
post #1098 of 1437
We will be announcing within a few hours...
post #1099 of 1437
:O!!!!!!!!!!!!!!!!!!!!!!
post #1100 of 1437
Looking forward to placing an order!
post #1101 of 1437
Great deal on piano black Towers were posted in the Ascend Forum.
Edited by cschang - 11/24/12 at 10:41am
post #1102 of 1437
I see a discrepancy....it says they are priced 700 less than the original price of 2598 which should make them 1898, but the price offered on site is 1998.
post #1103 of 1437
Good catch. Dave will probably see this post and put up a correction.
post #1104 of 1437
Originally Posted by cyde01 View Post
Hey guys....
I have Polk RT800i's and Ascend 340's and have compared both side by side.
The 340's are much more detailed than my Polks (I use them in my workout room now) and are very neutral. A great speaker to be sure, You'll definitely enjoy the upgrade.
post #1105 of 1437
Hello everyone, with the cost of the Towers starting at $1898 with options and finish upgrades adding to that starting price, Ascend has now made that very expensive and extremely intensive process for the piano black finish now just $100 additional charge. In the interim release the piano black finish has been expensive due to the efforts required. Now that its just $100 additional hopefully more can use those funds maybe for the RAAL upgrade and still somewhat be close to that original piano black finish total. Hope this helps.
post #1106 of 1437
Ah...that makes sense, thanks for clearing things up Brain....seeing that AD the other day was somewhat confusing....redface.gif
post #1107 of 1437
Brian - when I went on there to order it was adding $200 to the total- bringing it to $2098. Is that fixed? Oh, with the RAAl upgrade it goes to $2798. Should it not be $2698? A bit confusing. Thanks
post #1108 of 1437
Hello there in Canada, I just went on the site to simulate a purchase and it did calculate the correct amount, now the "high gloss black" is a $200 charge which also came up correct on the Ascend Direct portion of the site. I'm blown away that the "piano black" charge is now so much more affordable, that is one crazy finish and I had no idea how complicated it is for that. Dang, no wonder baby grand/grand piano's are so expensive eek.gif
Anytime one finds a possible glitch always call us so we can investigate to ensure everyone has an easier and more pleasant purchasing experience. So, who will be the first today to get some of these beasts?
post #1109 of 1437
I am in a decision mode for one.
post #1110 of 1437
cant decide on raal or no raal. 100% movies.
  Back to Forum: Speakers
