what type of cable do I need and can I get it at monoprice? I am using a front projection setup.
Hate to be a whiney little b*tch but this xbox is killing me. I bought the 4gb Kinect bundle since I don't want/need to store anything. First off can't do hd since my hdtv only does component and the silly xbox comes with a proprietary connection and only cables for composite? I thought this was an hd gaming system? so I have to buy an extra cable for component. Then the composite cable stops working (TV working fine) so now i get audio but not video, don't know if its the cable or system.
Take it up to the projector room won't work on one hdmi cable that works fine with everything else, then try another cable and it works but then the kinect cable is not usb so I can't use any existing extensions I have.....
Would it really kill microsoft to just use standard connections like every other piece of electronics I have bought?
then whats up with the seprate power brick with loose connections, geesh, seems like a fire hazard.
ok rant over.
Halo better be worth it because my ps3 is killing it on first impressions.
ok rant over.
its really not a big deal, the OP is having probs with his kinect though ,thats where he has a problem.
