Originally Posted by craig john
I wasn't commenting about output capability. My point was that, if the frequency responses were different in the different positions, they would *sound* different, and that alone could account for the listening preferences you heard. I know in my room, if I move a sub one sub-width to the left or right, the FR changes... sometimes quite significantly. The SPL measured at the listening position may not change at all, but the sub will *sound* different based on the FR it "sees" with it's different interaction with the room.
That is why I said it would have been interesting to swap positions and re-listen. If the listening preference would have stayed with the in-room position, it would mean the FR of that sub position, (and that listening position), were better than the other. If the listening preference had moved with the sub, then it would have been absolutely clear that one sub "sounded" better than the other.
Does that make sense?
I agree with all the other posters that I appreciate your efforts in doing the comparison, and more-so, I appreciate that you were willing to take the time to write up your impressions. This is a valuable data point for others considering these 2 subs. I know, if I was in the position of looking at subs in this price range, I would give strong consideration to your viewpoints.
If you guys repeat the evaluation, I hope you can address the in-room position issue. (It sounds like you're going to!
) Keep up the excellent work.
Craig, (John), (not craigsub
)Craig I understand what you're saying, and I'm sure Ethan does too, and I completely agree with you. Like James said these and other points made by other posters were good ones. I just purchased the 18.1 and we will be doing another shoot-out with both subs in the exact same location. Now someone mentioned about eq. The problem I have with eq is that I would still have to get both completely flat and then calibrated even for it to be "fair" correct? Because if I didn't then it would be the same scenario where one sub could have a slight boost at one frequency and the other sub another one. I'm not saying that's not possible to get a flat response but it's definitely not going to be that easy either. I could get the anti-mode and I have Audyssey in my receiver as well. I don't have the time to learn REW unless someone in the area could show me how because I'd probably pick it up quicker that way. What do you guys think?
Actually to hear just one would be nice? You have one too allredp right?
But unless the subwoofers are going to be in the exact same position (which is next to impossible with the size/weight of these things these days), it's soooo difficult to compare. Like MojoMike said, it's hard to believe they'd be that different in SPLs. Alternatively the "swap the positions of the sub and redo" would be good as well.
You gotta love it!!
