Thanks for the ideas Brad. I figured I would stick with the rigid stuff for the panels, just needed clarification, that's all
Well, once again I disappoint with the lack of pictures but I can assure that I am making progress
I finally got around to start painting my econowave cabs which I will finish tomorrow!
On a different note though, I am ready to order my 4 IB3 drivers but I just need to figure out if I should order the single 4ohm drivers or the single 2ohm drivers. I'm figuring the single 2's that way I can wire them in series to create a 4ohm load on each channel and stay safe, less heat anyway. Since the driver's RMS is 550 watts I believe, the EP4000 amp should be able to provide that without sweat even at 4ohm to each channel. Let me know if you have any other thoughts on that or any reasons to grab the 4ohm version
Pictures are coming, sometime soon
