I would use expanding foam in between the studs and wall, then 1-1/2" to 2" of pink insulation inbetween the studs sealing the gaps with expanding foam again.
The pink foam at that thickness gives you the required vapour barrier anything thinner will not work as a vapour barrier.
Do not use fiberglass with the paper backing that will create a double vapour barrier, which you do not want.
Other methods would be to spray foam everything, costly but eliminates your problems of gaps behind the studs, vapour barrier needs, etc.
