Thank you all for taking the time to respond. I have not done much more since last week, I've been busy renovation my bedroom and closet. I decided to come back down tonight to play around and did find something interesting. After I did the following test, I guess since the MFW's can't compete with the IB's, they actually won't do much good. I decided to unhook my IB's and run my MFW's only to see what results came of that. I found that with both MFW's in the front of the room, I got similar results (as compared to the IB's alone) only with about 7-8db less output. Now, if I have one MFW in front and the other right behind the rear center seat with the driver firing against the seat, I got MUCH better results in the back row except for a small sharp null at 30hz. My front row still had a huge 60hz rise but was smoother going up to it. Bottom line is that because the MFW's can't put out what the IB's can, it seems that they won't be much help in my situation.
To answer one of Fred's questions, yes, the the subs are level matched. If I play the IB's alone vs the MFW's alone, they both show 75db on my meter while using the receivers' test tone. I don't know why MFW's alone test at about 7-8db lower than the IB's alone
Also, all polarity seems fine, nothing out of wack.
Also, about placement. I don't feel the need to do a crawl test since I only have a few potential placement spots, but I wil try other tests to see what helps.
Here is graph comparing the IB's (with and without the rear MFW's) along with the MFW's alone. The red lines show the IB's alone vs the IB's with the MFW's in the rear, you can see that the MFW's helped slightly, by only by a few db. The blue lines show the MFW's (both up front vs one up front and one in the rear), what a difference! All FR's are of the rear row where I have that large 30hz mountain.
