Originally Posted by mystic_sniper28
looking at those sub boxes I would suggest 1-2.5' off the primary wall, so you'll be looking at a false wall at 2.5-3' or may be 4'..
you could insulate the boxes a bit though I'm not sure if that would help your situation, I would say it might be better to dome the wall behind the subs might help deflect some of the reverb noise...
I'm not sure what you are trying to get at. Those boxes aren't for my subs, they will be my LCR's and will be flush mounted into the wall. I don't have the length in the room to do a false wall 3-4' from the rear wall, so my screen will be directly on my wall but spaced out a little to leave breathing room for the LCR's.
Also, what is my situation to where I might need insulation in the boxes?
