Just a thought.
With everything connected and the lighting not working, have you ever looked at the front panel of the pro2 and looked at the status LEDs next to the computer port on the left hand side? You should have only "PWR" and
"NET" illuminated. The third status LED "MSG" should be off.
"MSG" is the same as "ERR" in older units and has the same funtionality and you know what ERR means
