AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › Panasonic 36HL43 WON'T turn ON! HELP!
post #1 of 4
Okay, I was watching my tv on Tuesday Night
11-16-10.
EVERYTHING was fine!
Wednessday, NOTHING!
TV will NOT turn on!
There were NO crackling noises, or hard starts
or anything of that nature!
What happened?
And HOW MUCH will it cost to fix it?
I CAN NOT
AFFORD ANY TV right now.
I have way TOO many A/V pieces right now, that
either WON'T turn on at all!
OR won't work properly!!!!!
I NEED HELP! AND ALOT OF MONEY!
post #2 of 4
either WON'T turn on at all!!
Check the power source/power strip.
post #3 of 4
Duh! I did that already!
I swapped the ac cord into another power strip!
That did NOT work!
post #4 of 4
Duh?
Did you try another power outlet?
Have you tried the problematic devices directly connected to a different "power source"?
How many devices are affected?
Did they all die at the same time?
