All my speakers are rear access. Its very easy to do. Im doing it with my new QSC build. I molded the QSCs right into the baffle, no seems at all now.
Build the box normally then cut out the access you want on the back. Keep the piece you used and glue it to a 1/4" MDF piece that fits flush on the back of the speaker. 1/4" MDF is easy to sand down to very thin/smooth corners that blend really well on the back of the speaker.
