Here are some opinions (not to be confused with facts
If I were developing another compression driver WG today, I'd do as Josh suggests and go with a super elliptical PS. (Wish Josh would have mentioned SE before I went with an elliptical mouth!)
The original sims, and subsequent measurements, seem to indicate a lower diffraction profile for the elliptical/PS. Subjectively, I easily prefer them over my earlier 80 degree OS WGs. The exact profile hasn't been publishedtrue, and it probably never will be. The time investment was so high, it feels like giving away a family heirloom. That said, it would be relatively easy to take the core concept, hone it with your own set of design tradeoffs, and build them. I did the sims with a laptop running Axi-Driver, the build by hand. A fast computer and CNC should make quick work of it.
Assuming availability with any motor and phase plug, my first choice for CD diaphragm material would be beryllium, followed by titanium nitride, then aluminumbut only if they came with a non-metal surround. Measurements provided by 18Sound show better low-end distortion with a plastic surround (midrange distortion products are more objectionable than the 2nd or 3rd harmonic of 7k).. Plain titanium is not on my radarhaven't looked at plastic diaphragms, but I suspect Josh is correct again. Since custom diaphragms/surrounds are out of my league, I'll settle for aluminum/plastic.
BTWcurrently working on taking that vertical directivity thingy a little lower in frequency
)If I were developing another compression driver WG today, I'd do as Josh suggests and go with a super elliptical PS. (Wish Josh would have mentioned SE before I went with an elliptical mouth!)
It is funny how we each perceive the challenges of speaker building through the lens of our own skill set.
