Originally Posted by bwaslo
Actually, that would probably work really well for LR, too, if they could be mounted up against the ceiling, woofers at the top of the baffle near the ceiling to avoid reflection (ground-plane style), and of course toed in to cross ahead of the center seat. Not living room WAF style, of course, but it could be a sell for dedicated home theaters.
Edit: Now you got me thinking. First, speakers hanging from the ceiling might be better done with neo type woofers (NS6 buyouts come to mind again) to cut the weight down. The Malcolm using DS woofers is currently a box-o-magnets with all those big ferrite woofers.
Second, probably the long bottom side of the box (will be top side against the ceiling, when mounted woofers-above) could be sloped to move the baffle edge closer to the ceiling for that kind of installation.
Erich is better at cutting wood than I am, maybe when his day business settles down a little for the season I can talk him into making boxes like that to try. I need to finish up the DeltaLite 2512/Delta 12A/Designer 12 SEOS12 Ewave designs before getting sidetracked onto this. Or maybe someone else wants to take on the "Reese" ceiling mount speaker design?
Those look like they would work phenomenally for surrounds! Besides the physical shape of the enclosure, what would be the pros and cons for surround duty when comparing a high efficiency 10" woofer + SEOS-12 versus the horizontal line array of 4 or 8 - 6" woofers paired up to an SEOS-12?
