Originally Posted by bg40403
The speaker bwaslo is dreaming up should be able to be mounted with a hook and pivot motion. Hook one edge in a positive way to carry a significant amount of the weight, then pivot up to final position and make the connection which secures it in place. It can and should be designed so one person can do it, unassisted.
Good idea. A hook toward the listening position to place the thing and pivot on and support the weight, then another chain or something in the back to point it and pull the back to the ceiling.
(Do any of this at your own risk and ingenuity, BTW -- I'm not responsible if one of these falls down and clobbers anyone or anything!)
It's the correlation between what I'm seeing and what's causing it that is my problem currently. I've got some group buy drivers on the way and starting to feel the pressure to up my knowledge base a bit!
Your posting of the crossover schematics is really fantastic and a big help to guys like me looking to start learning how to build and design crossovers. I have a couple of speaker building and active/passive crossover design books on the way and lots of reading to do!
Did my mass speaker designing this past week, got to get back to some other things now.
