AVS › AVS Forum › Audio › DIY Speakers and Subs › Hey guys...we need a little rallying here...
Hey guys...we need a little rallying here... - Page 126
post #3751 of 7503
Originally Posted by cookieattk View Post
right now i have a 2226 in a 1.4cf with a 18'' ae pr, f3 of 18hz...
Is that with EQ?
I had similar for awhile, except ported, and while there was a local peak at 18 Hz output was way down compared to 80 Hz.
post #3752 of 7503
For me I would have the 2226 ported around 35hz and hpassed where applicable.
Perfect application for 6th order ported.
post #3753 of 7503
Is that with EQ?
yes with eq i needed +12db from 20-30
post #3754 of 7503
Wow, that's a lot of gain. As a policy I make a conscious effort to hold EQ gain to 9dB or less. If you don't do that you are much more apt to clip on dynamic passages.
Even tho I hold at 9dB the 'limiter light' will sometimes flicker.
_____________
Best Regards,
Carl Huff
post #3755 of 7503
_____________
Best Regards,
Carl Huff
not really as long as your amps up to the task it doesn't matter.
post #3756 of 7503
If you are doing all of your gain in the analog domain I can see where you are more apt to get away with it, however you are still trading off for less dynamic headroom and higher distortion.
In my case it matters more because I am doing most of the gain in the digital domain and will quickly 'run out of bits' if I'm not careful. Digital clipping sounds particularly ugly.
_______________
Best Regards,
Carl Huff
post #3757 of 7503
Originally Posted by carl_huff View Post
my problem is that i get distracted by my 'next great idea!' and wander off to explore that and fail to fully complete existing projects.
Argh ...
____________
best regards,
carl huff
Stick to the original plan Carl!!!
post #3758 of 7503
SEOS/EOS: 24", 20" or 18" for 1.5" drivers - please vote.
post #3759 of 7503
24. For an 18 there are 1" drivers that will do it.
post #3760 of 7503
+1
post #3761 of 7503
Thanks and for 2" EOS 30"?
post #3762 of 7503
I agree and Yes! I would immediately buy a pair of both if they were available today.
_____________
Best Regards,
Carl Huff
post #3763 of 7503
What would be really cool would be if the exit angle were matched to a TAD 4001 - since only crazy people would do it anyways
post #3764 of 7503
I guess that accurately tags me as I have already committed to buy! Ha, ha ...
_____________
Best Regards,
Carl Huff
post #3765 of 7503
Can you remind this angle?
post #3766 of 7503
SEOS 24 is ready with throat angle 14deg, waiting for Radian 950/951 and 18sound ND4015BE, NSD1480N, ND2060A angles.
post #3767 of 7503
Radian 950 = 20 degrees. 18sound 1480 = 10 degrees, 2060 = 18 degrees.
post #3768 of 7503
Ready, thanks for info.
post #3769 of 7503
who put together this version of the logo?
I didnt forget about the logo, but i feel like a newbie because big badda boom put the oval in the center of the O and i cant figure out how to replicate that in illustrator to make a vector version of this..
post #3770 of 7503
post #3771 of 7503
I haven't been able to contact him about it. I have a lady friend that's a graphic designer and she could make it, but I'd rather see if he was able to easily make us a bigger photo.
post #3772 of 7503
On the bigger SEOS, the drawing looks more like the size of a SEOS-22 or so, which I thought was the better way to go for shipping and things like that. Wouldn't the SEOS-24 be around 25+" wide? I guess it doesn't matter what it's called anyway.
If there isn't much difference between 22" and 24", I think it would be best to stay on the smaller side. Seems like a total width of about 22"-23" wide would be ideal, but that's just my opinion.
Mother's Day is almost here and it's hell week at work. But once it's gone, I'll have a lot more time to start focusing on the other parts of the SEOS project. Mainly the flat packs and front baffles.
If anyone has any cabinet volume or dimensions they are good, please let me know so I can start planning something out. That way we've got things to pick from once they finally arrive in a few weeks.
post #3773 of 7503
I would like to see a slim sealed cabinet, something like 12-14" in depth. Do you know how much volume the seos 12 takes up?
post #3774 of 7503
I'm looking forward to an SEOS-12 surround using 2 or 4 high efficiency 6" drivers like the NS6. Something like the Malcom, but flipped upside down.
post #3775 of 7503
Do you have measurements for the EOS 30?
SMathews
post #3776 of 7503
Not sure if this is what you were asking......a flat-pack cab that fits the 10" one-piece baffle would be slick. Just add veneer for a premium speaker with minimal sawdust. Sized to fit the Eminence Deltalite would be nice....
post #3777 of 7503
This is only CAD file. Some simulation can be done.
post #3778 of 7503
+1
Initially, have flatpacks for the SEOS 12 designs that Mr. bwaslo has kindly provided. Those will go like hotcakes once the drivers and waveguides are available.
post #3779 of 7503
^ +3
post #3780 of 7503
^^^ +11ty billion
