AVS › AVS Forum › Audio › DIY Speakers and Subs › Hey guys...we need a little rallying here...
Hey guys...we need a little rallying here... - Page 134
post #3991 of 7567
Ha, if you guys knew how this was going down.....you'd stay far far away!
I'm hoping to have a couple of the landscaping employees help unload everything when the truck gets here because the shipping company does not give much time before they start charging extra to sit there. I'm clearing some space at the shop tomorrow because a huge amount of room has been taken up by the flat packs and shipping materials.
My sister said she would help with some packaging, but we'll see how it goes. My father said the same thing. But he hasn't been to my shop in quite some time and really doesn't know just how crazy things are getting.
I'm going to be spending most of today packaging up subwoofer flat pack orders and the JBL 15's. I've got the PM's from everyone that requested the JBL's, so I will contact you once they are packed and weighed.
4 new landscape jobs popped up that I wasn't expecting, but 2 are small and won't need to get done for a few weeks. The others are a bit later. I do have some big floral installs to do this week and I always make sure I'm on site for those. Other than that, things should start to open up and run a bit smoother. My biggest "problem" right now is actually switching gears from scaping to audio stuff each day. I really need to hire someone part time that starts around 1:00 and works until 6:00 and 3 days per week. Then I would HAVE to be there. Maybe a good high school kid.
Erich, i sent you PM. Did you read it ?
post #3992 of 7567
Originally Posted by coctostan View Post
I assume you mean side by side. One on top of the other would give you a directivity mess IMO. Beyond that, I see no reason to use a midwoofer with that much excursion capability with a horn that size. I'd suggest more surface area and less excursion. The only reason to use something like that is if you need major bass output from a 7" woofer. If you are using any subwoofer at all, going this route is a mistake. IMO, you want to limit the excursion of any driver that will produce content above ~150-200hz thus making this high excursion mid a waste.
If you want dual 6 or 7" woofers side-by-side under the SEOS-12 I'd suggest either dual RS180's or dual Aura NS6's. Even better, you could do four of either of those in a square pattern. I don't know if you are planning on doing passive or DSP, but this wouldn't be too hard to deal with.
Yes, side by side. What you say makes sense. I want more efficient anyways.
I really want to figure out what woofer to use in a 12". I have 3 ts12m's ordered, but who knows how long that will take. Any suggestions? I would run these with subs and will build them LCR.
post #3993 of 7567
I have seen the horizontal directivity chart on Erich's SEOS sales page. Has the vertical been measured?
At what freq does SOES 12 start to lose vertical directivity? What is the nominal vertical directivity of the SEOS horns? 45, 50, 60?
Rich
post #3994 of 7567
Thanks Tytte71. Large damped rear chamber sounds intriguing!
I did measure the 475 in QSC with mic only 1/8" from the CD throat screen, the dip at 8200 disappeared, so it is just related to the QSC horn.
post #3995 of 7567
Since you have TD12's on the way, I'd build for 12" woofers. Try either of Bwaslo's designs, the Designer12 or Deltalite 12. They are well done and will give you excellent performance. When your TD12's show up you can swap them in and use a different crossover. There is a chance it will only require a modification of the crossover but that is speculation at this point.
Rich
http://larchive.avsforum.com/www.avs....php?t=1369780
This thread has detailed measurements courtesy of Bwaslo and Erich. Vertically, it holds pattern of 60-70 deg from about 2khz narrowing to about 40deg at around 10khz.
Horizontally I'd say it is about 80-90deg from about 900hz and up.
It is likely the combination of the QSC and 475. Not all phase plugs propogate the same wave shape and this can cause nulls such as this. I've not seen this issue with the QSC and other CDs such as the CP380, 4550 or DE250.
post #3996 of 7567
post #3997 of 7567
and ? poo pooing competition is normal .
post #3998 of 7567
Hey Cookieattk,
I tried to reach you last week regarding your fv15-hp. If you still have it for sale can you pm me.
post #3999 of 7567
Keep us posted to the reality of lead times for the AE 12s.....
post #4000 of 7567
That is funny. I'd like to see his critique and comparison of how the H290C is "superior in every way". It certainly seems odd when he posts measurements that are frankly far inferior to the SEOS-12. Of course, his measurements have the disclaimer that the lack of a baffle mount is inducing the waistbanding he sees around 1.7khz. Although this is true, it would behoove him to post what he feels are representative measurements and then make the claim that his are superior. I understand he prefers a 50deg vertical pattern over a 60deg but frankly that is splitting hairs, especially if you can maintain wide nulls. Beyond that, the SEOS design is well documented in its spec's whereas Wayne has not published the profile or any other specifications of his H290C.
I respect Wayne and I've learned much from his approaches and papers. IMO he brought reasonable horn speakers back to the home user. I know his work inspired Zilch. With that said, I can't help but feel that he feels a bit threatened by the SEOS and before that the QSC. He basically existed without competition in the DIY market before. I still forward people to him who are looking for a more established design with PCB's available.
Although he was being quoted from a private email, which IMO is a no-no, I'd like to see him either retract that statement or support it with facts and detailed opinions. I know he is an AVS'er and quite capable of doing this.
post #4001 of 7567
This is not meant as a slam on Wayne and may a dumb question but what is the difference between his H290C and the H290S: http://www.parts-express.com/pe/show...number=290-555? They look the same to me.
post #4002 of 7567
Why do you immediately think Wayne did wrote that in the first place ?
I don't see him writing that stuff but some guy who claims that Wayne sent him mail. Wouldn't jump to conclusions that easy.
Regards
post #4003 of 7567
We didn't really use a baffle mount either.
post #4004 of 7567
Okay, CRAZY NEWS UPDATE.
I've been emailing the shipping company in Seattle for the past couple weeks and all is good. Of course you would assume that after you pay, they let the container go and schedule a delivery time. Pretty simple stuff.
I got a phone call a few minutes ago and the woman asked when a good time would be for delivery.....exciting news of course. She was joking around a little bit, so I said "Yesterday would be a great delivery time."
She said "I've never liked going back and working on past Sundays, but how about early this afternoon." Obviously I think she's still joking and I ask if they're going to fly the container directly to my shop on a plane. She says "No, the container is at our Cincinnati facility already."
Turns out that it was shipped from Seattle last week and it's already here in Cincinnati! No one told me that!
So I'm going to try and scramble some guys together by this afternoon to help unload all of this in the short time slot they give. The problem is that all the employees are already out mowing or mulching, so we'll see how it goes.
As mentioned earlier, if it's not done today, they charge $75 per day for storage. But if it's not unloaded in their time frame, it's $65 per hour for the driver to wait. And if they drop off the container and leave it for a couple days, it's $125.
I'd let them drop it off, but up to this point I'm sure they use cranes to move these containers and keep them level. But if they drop them off, my guess is that they'll use a truck with a roll back system. Well, I'm sure it's all secure, but I'd rather not take that chance of angling the stuff that much. Now if they just leave the trailer and container, then I'd just pay the $125.
Either way, this is exciting news!!!!
I'm waiting on the dispatch to call me back to explain how they drop the container or get an idea how late in the day they can deliver. It would be great to have this done today.
post #4005 of 7567
I can't get there in time, or I would help.
post #4006 of 7567
I love it when you get a surprise and stuff you're eagerly awaiting arrives early.
Erich, is there a local business that would be willing to help you with a forklift? I've had the good forutune of businesses lending a helping hand when in need.
post #4007 of 7567
Wow!!! This is great news that the stuff is here and practically on your doorstep. You'll be running around like a madman today! Good luck!
-Nate
post #4008 of 7567
(Eagerly awaits pictures of buttloads of boxes)
post #4009 of 7567
PassingInterest, I know you would help!
This is certainly some crazy unexpected stuff.
I just got off the phone with them and she said they can leave the container and the truck chassis at my shop. That obviously keeps everything perfectly level. No doubt it was originally packed okay, but you never know how US Customs will leave it, and I don't want the container angled. No problem though.
It's $125 for the container to sit a couple days. Of course they charge $20 extra per day for the chassis to sit there. Which basically means I'm not going to let the thing sit for more than 1 day. But at least it will give me time this evening to unload it all without rushing to get employees to come back mid day.
I've got a small and a large skid steer (a.k.a 'Bobcat') with pallet forks. But they didn't load the stuff on pallets. I guess pallets don't let you pack things in as well, so they put the stuff in cardboard boxes and stack those. So this is all hand unpacking!
And yes, there's a lot of things coming.......I just haven't said anything yet!
post #4010 of 7567
FWIW, I believe I've seen a couple of posts where Wayne refers to the SEOS12 as a 120 degree horn, so that might be part of what he's talking about -- too wide a pattern for his liking. Looking only at the autotech graphs, 120 degrees seems accurate. bwaslo's actual measurements look more like 90. I forget if that difference was ever explained.
*Would* be best if Wayne elaborated with measurements/comparisons, though.
post #4011 of 7567
it is a 90 degree waveguide, definitely. By both design and measurement.
post #4012 of 7567
Nice!
post #4013 of 7567
The truck driver is on his way. Should be here in less than 30 minutes!
post #4014 of 7567
YES! You've got to post some victory pics when you get all the stuff laid out at your shop!
post #4015 of 7567
Uhhhhh wow, this is crazy.
BWaslo said I was insane, and now I believe him. There's a lot of stuff here. I'll explain later.
I opened up the rear doors of the container, laughed at myself for a second, climbed into the back, and laughed again. Now I'm pondering where to put all this stuff.......hundreds of boxes.
I've got the space, I just need to move some equipment and flat packs around. It's more boxes than I actually thought.
This is funny stuff. Man, I really am crazy.......and today it finally hit me! You guys probably knew it all along and just didn't tell me.
post #4016 of 7567
We need pictures of the insanity!
post #4017 of 7567
Yes, crazy, but its good crazy.
post #4018 of 7567
I can't even get up in the back to get pictures yet!
Here I was thinking I could put a good dent in unloading this by the time the employees started trickling in from work later today. Not a chance.
I just called in for some ground support. The cavalry is on it's way. Well, some of it anyway.
post #4019 of 7567
On an unrelated note, it appears that AudioKarma.org is GONE!?
Sure hope someone backed-up all the Econowave thread.
post #4020 of 7567
It's still there and running. There appears to be a DNS issue depending on what your ISP is, I can get to it on one ISP, not the other.
