Originally Posted by
bwaslo
Hi Java,
It's the 12a, not the pro. Though if it were me, I'd use the Designer 12, but you maybe play louder than I do. The designs I did are for woofer and waveguide on the same mounting plane, either both front.mounted or.both recessed the same amount. If you change that, the crossover will need redoing.
Porting is pretty safe to do, just use a good modeler (such as WinISD) , and if possible have away to check your tuning such as a woofer tester or measuring setup.
Baffle try to keep around 15 inches wide, waveguide above woofer, waveguide horizontal and as close to woofer as you can. Arrange for waveguide to be at ear level and for the speakers to be toed-in considerably.
If you.can have big roundovers on the baffle and make sure the box is well braced (i like window braces, but not everyone agrees).
And - Don't.try to type long replies on a smartphone's keyboard, it.will drive you nuts!
Thanks much the reply. Sorry for giving you mobile typing cramps.
Great news on the 12a. On 12a versus Designer 12, I definitely noticed your like of the Designer 12. How much of that may have been driven by the "test mule" sealed cab? If I'm going a larger ported cab, with that change the dynamics?
Hard to say if I listen louder. Very subjective, but I do like to crank it for movies. The 12a seems so more efficient than the Designer 12. 12a SPL: 98.3 dB 1W/1m vs Designer 12 SPL: 90.4 dB 2.83V/1m (couldn't find a 1w reading). I realize there are many other factors than just sensitivity and many that aren't in specs. The price is right between the 12a and Designer 12. In a larger ported cab, what do you think the trade offs would be?
Great news on even plane for the drivers. Makes it much easier. I'll front mount the drivers, so no need for round overs.
On the ear level placement, per below (as reference, screen is 126"), I have a constraint on center speaker, but can get the LR up higher via stands. My design goal is to try to get the speakers to be 30" tall. Also, for toe-in, I was planning on "corner loading" them per your toe-in guide. I have the room. On that note, your toe-in guide was for LR vs LCR. Any impact of a center channel? I would think not, but worth asking.
Thanks, again!
Edited by Java - 6/22/12 at 1:02pm
