AVS › AVS Forum › Audio › DIY Speakers and Subs › Hey guys...we need a little rallying here...
Hey guys...we need a little rallying here... - Page 208
post #6211 of 7533
Originally Posted by Erich H View Post
I think the 3D file needs a decent amount of work after it's cut. There's work around the throat angle, and roundovers that gets worked on by hand with the original molds.
Oh certainly, I'm not looking for anything "mold ready", I'm mostly interested in just the internal profile of the waveguide (since my limited understanding of how they work means I don't really understand how that shape is generated, and why it follows the curves it does). The throat, mounting points, flanges and whatnot I am comfortable generating and fabbing on my own. Even if there aren't 3D files available for the SEOS in particular, does anyone have any others that they know of, or even some resources to read on the math behind the shape itself?
Sam
post #6212 of 7533
Originally Posted by Sibuna View Post
So i plan on using the Tempest 12 to use as LCR, what would be the best bet for surrounds? one of the 10in woofer models or?
If you want to keep everything timber matched, go with the 10" Delta Max.
post #6213 of 7533
erich, with respect to the ae speakers td12, are you referring to the td12s or the td12m?
I'm not really sure. I was just saying i would get the boxes or the baffles for what ever people thought was needed.
post #6214 of 7533
The BA750 has fantastic build quality, but I'm single, so I figure now is the time for a huge horn system. You're right about the need for a sensitive supertweeter IMO. 24-SEOS takes a 1.4 CD, so that's what I'm looking for.
Originally Posted by FredrikC View Post
But seriously, I doubt many 1,4" CDs will do 500hz. Maybe 600 with steep XO. And you will probably have to look in the higher price ranges. JBL 2452H-sl, TAD4003, or maybe the new 18 sound 1.5" exit drivers.
You might even need a supertweeter since the polars will start to beam above 12kHz, instead of 16kHz with a 1".
But if size and funds are not limiting factors I would be doing that as well.
What can you tell me about the BA-750 / Seos 18" combo? Are you not satisfied with the sound or are you just curious about going bigger means even better? Done any measurements?
post #6215 of 7533
ive posted this before but since its been brought up again.
http://www.faitalpro.com/products/HF_Drivers/product_details/index.php?id=502020150
post #6216 of 7533
Hey, shouldn't you have posted a review on the website for that thing? biggrin.gif We need reviews for all this stuff!
post #6217 of 7533
If you want huge horns, order the Iwata 300hzs. They are beauties, and I am too single and get away with it. I am still using SEOS for my HT, but the Iwata's are in my stereo audio system.
post #6218 of 7533
post #6219 of 7533
Very interesting, Josh - is it that you find something about the SEOS superior for high-volume situations, with the Iwata is....?
post #6220 of 7533
I have the SEOS 18/TD15M/BA750. Sorry but no review or build thread for awhile. It took almost a year to get all the parts esp. TD15Ms. In the interim I started on a large living room/ kitchen remodel so the speaker project is on the back burner for awhile.frown.gif
Yes, the BA750 looks like it can kick some serious azz and it's got the hindquarters to do it.eek.gif
post #6221 of 7533
post #6222 of 7533
I am married so my "big" system is banished to the man-cave. It is/will be a work in progress. I opt for the Iwata 600.
BA750 in hand
Iwata 600 pending
Edited by bg40403 - 12/14/12 at 8:31am
post #6223 of 7533
Both will be done. The TD12's are already underway. Just curious about exact internal volumes so I know which box they will go with.
Eric,
Would you know of any design in the pipeline that uses a AE TD12H for mid/bass duties?
post #6224 of 7533
I will be doing one VERY shortly with the td12x.
post #6225 of 7533
Good to know. Will be on the lookout for your thread, good luck!
post #6226 of 7533
Received all my crossover parts for the Daniels. Erich, if/when you get the baffle done, I'll be ordering 5 more SEOS-12's and 350 compression drivers. biggrin.gif
post #6227 of 7533
I'm getting in a lot of baffles and other things today. I'll get them listed.
The Daniel baffles were made a little large to be on the safe side, and so I can cut them down to the proper size before adding roundovers.
What size would you want those baffles to be?
For the guys using the A&E 12" woofers, will you be leaving the large gasket around the mounting flange or not?
Edited by Erich H - 12/14/12 at 12:07pm
post #6228 of 7533
With a slight change to the bracing, the 12" woofers will fit in the smaller 1 cuft enclosure. There's about 2.5" between the pole vent and the back brace on the Definimax. The box is 10.75" deep and has a double thick baffle with one vertical and one horizontal brace.
Edited by Erich H - 12/14/12 at 12:13pm
post #6229 of 7533
Make the cutout to include the gasket. At least that way the woofer will fit with and without.
post #6230 of 7533
oooooooooof, after much banging around and figuring what I wanna do I think I'm focusing in on the waveguide speakers.... I have a few questions for the masters like Erich and such who have built a lot of these. I was told by ack_bck that the Delta 10 set should pretty handily stomp my Polk Moniter 70's and CS2 center for home theater use. My situation is that the Monitor 70's are just too big for my area (they dip into my projector screen a bit). I have two monster THT's corner loaded that take care of the low end so I crossover at 80 hz on my receiver.
I had Ack_bck mention that I might not seem much difference between the Karma 10's and the Deltalite 12's in my situation because of the 80hz crossover and I won't be using the 12 inch woofers lower frequencies as much. My question to you oh Gods of the waveguids is where is that "sweet spot"??? am I not going to see much difference in upgrading past the karma 10? I mean am I going to see double the improvement in my situation (since it's near double the price between the Karma 10's and the Deltalite 12's)... or maybe go with one of the other "in between" kits? I guess you could say which one is going to be my "best bang for my buck" scenario with the situation I mentioned above.
also since I'm powering them with my Onkyo 605 and not an amp where is the stage where I'd have to use an amp instead of my receiver, I noticed the Deltalite 12 and Karma 12 had a big power increase and DIidn't know if I could fully drive them with my onkyo 605
Edited by wormraper - 12/15/12 at 6:40pm
post #6231 of 7533
I hope other experts chime-in on your comparison question. I will be replacing some Klipsch towers (dual 8" mid woofers). replacements will be SEOS12s over the 12". Delta lights. I am hoping to hear more impact in the frequencies just above my 80hz x/o
post #6232 of 7533
I don't know what Klipsch towers you have, but I replace the RF3s with the CS1s (which is a similar 2 way designs as the SEOS).
1) Huge imaging
2) Greater dynamics
3) Mid bass kick is awesome
4) That bright harshness is gone
The CS1s also use an Eminence woofer.
I am hoping to build the SEOS soon to replace the CS1s as my fronts. Hopefully I will get to hear the difference soon.
post #6233 of 7533
Smokarz
Thanks for that info - very encouraging!
I currently have the RF35s. Based on your input my upgrade result should be very nice!
post #6234 of 7533
Smokarz
I'm going to SEOS/TD12M from Klipsch RB-75 system and think it'll be a nice upgrade.
post #6235 of 7533
The recess that you routed for me was just large enough for the large rubber gasket that comes with the TD12M.
post #6236 of 7533
Yes the SEOS-12/TD12M is a nice upgrade over the RB75's.
post #6237 of 7533
I also have M&K S-150 in the special real wood mahogany, but those are still in Cali. I always liked the Klipsch, but never loved them.
post #6238 of 7533
A selfish interruption to our regular programing:
Spent several hours this weekend working on the enclosure for "Big-Mal". My SEOS "Big-Mal" (aka BUC) build can be found here:
http://www.avsforum.com/t/1440063/diy-seos-for-ht-upgrade#post_22651962
Here's a teaser shot showing where I am with "Big Mal".
This is with a borrowed waveguide. However; I have some of my very own drivers, waveguides,and L/R delta-light flat-packs on the way, WITH a Big Mal baffle smile.gif
post #6239 of 7533
Erich,
Any change you could tease us with some TD12M baffle eye candy?
post #6240 of 7533
cuzed2,
I don't think that's going to look ugly at all. The dimensions and layout on that baffle area look rather nice to me. Big, though, of course. But that should make for a great center.
