AVS › AVS Forum › Audio › DIY Speakers and Subs › Hey guys...we need a little rallying here...
Hey guys...we need a little rallying here... - Page 229
post #6841 of 7535
Originally Posted by Erich H View Post
9" high would be too short for any waveguide speaker I can think of unless you put the waveguide right between two 6.5" woofers. But that's not a good idea. Maybe there's a chance of that with the smaller 8" waveguide, I'm not really sure.
Even 8" woofers need a box that's 9.5", so it would be tough.
About the smallest I could see working would be ~10" with 6 Dayton RS75T 3" mids below the SEOS-12 and a pair of 8" midbasses on the sides. It would obviously be a 3-way. The RS75T's are only 2.3" tall and you can fit 6 across easily. You could do 4 with a higher crossover point but you would lose some sensitivity.
When trying to maintain a timbre match across the fronts IMO it is as important to match the mid's as it is to match the highs. I would probably use the same drivers on the L/R but with the midbass's above and below instead of on the sides.
The real catch here is that no crossover is designed for this. Going active DSP would get very expensive with 9 amp channels.
One other possibilitiy would be a SEOS and a single pro 8" woofer to one side. This isn't something I've done and I haven't thought about it much so I don't really know what warts it might show. Directivity is obviously going to be a bit funky but I'm not sure what that translates to as far as actual performance.
post #6842 of 7535
Originally Posted by goonstopher View Post
Eek a little pricey but guess it's a long term solution buy...
I bought a Skill brand plunge router from Lowes for like $100. Works great.
post #6843 of 7535
The Ryobi RE180-pl is another cheap router that will get the job done, $99 at home depot. Its what I used for my quad subs.
post #6844 of 7535
Originally Posted by bhazard View Post
So I'm interested in putting together a full SEOS 7 speaker system. The Sentinel 15's intrigued me, but I have limited room for the center channel. I can only go 9" high, 13" deep, and ~26" lengthwise.
What would be good designs I could use that would be timbre matched? The surrounds would be 8 or 10" woofer sizes.
Would it help you to mount the waveguide outside or on top of the box? IDK if you could tolerate exceeding your dimensions with just the waveguide.......
post #6845 of 7535
I had a Home Depot gift card I wanted to use, and bought a Ridgid plunge router there, and have been happy with it - also about $100.
post #6846 of 7535
I had been PM'ed about a possible center channel for the MTG-08/Karma-8 design. If you could live with about +- 15 degrees of horizontal coverage when placed horizontally I simulated a 2.5 way MTM design based off the MTG-08 that could be made 9" high and sensitivity is bumped up into the mid 90's.
Also it would not be too bad setup vertical and used as mains or surrounds.
post #6847 of 7535
thats something i may be interested in. smaller footprint vs the big mal
post #6848 of 7535
Neat!
So, at a 12 foot distance, maybe the two middle seats are within the +/-15 degrees, and wider than that, they're more than 6dB down?
post #6849 of 7535
It's not that simple. Erich and I were batting around the idea of a center for a while and eventually decided it was to expensive.
You would have to look at the shape of the lobe, which should really be looked at with measurements. And also consider sidewall reflections. With a 2.5 way like mtg proposes, it's about the most cost effective way to do it with fewest compromises. But requires careful thought in the application. To say 6db down beyond 15 degrees is probably not correct. The nulls off axis are usually abrupt and deep.
post #6850 of 7535
Yeah it has its compromises; I am seeing almost -6dB at the crossover (1.6k) when you are ¼ the listening distance off center to each side for 12’ that would be about 3’ to each side. You might be able to get a usable 5-6’ window with the outer seats starting to hear the effects but like tux said move just a little beyond that and you are sitting right in the null.
post #6851 of 7535
i'm not sure if i am modeling it correctly in hornresp, but it seems that a front slot firing might work for minimizing height.
essentially the woofer would aim either up or down and fire through a slot like port either above or below the horn.
not sure if anybody does it this way or if my modeling is any good.
you have to use your imagination a bit, but the two triangles would be the woofers, down-firing into a front slot.
perhaps the drivers could be spaced to match directivity horizontally?
as another idea, why not just make that bottom slot another horn. possible?
Edited by LTD02 - 2/2/13 at 8:07am
post #6852 of 7535
LTD,
That's a pretty creative design. I wonder how well that would work for surrounds?
post #6853 of 7535
LTD, that is a possibility. It is basically a 4th order bandpass. This stuff can get tricky when modeling in hornresp because things like volume in front drivers can make a big difference at the frequencies we need. You might need to build up the area between in front of the cones. There could be lots of resonances to deal with.
I would actually do it with a slot on the top and bottom and 4 5-6" woofers. You could also add "rear" ports on the sides of the horn to make it a 6th order bandpass.
It is definitely a creative approach that IMO has merit. The issues are in the details which can be fairly complicated. A test box would be needed. Definitely not as trivial as a typical direct radiator.
post #6854 of 7535
Very clever LTD, and could work well. I've been studying maxmercy's thread and lilmike's threads with great interest.
As the mouth size goes down (as it would to keep baffle height within reason) the higher frequencies go up, so in this example it may work to your benefit. Max, I like the 6th order banpass, this would improve low-mid frequency extension, yes? So long as the compression ratio, mouth size, and the fold falls within the targeted enclosure size, this idea has potential to be something quite unique to the SEOS lineup. What would you consider for this, something with low Q? Whichever they are, the ratio will be high, and to maintain efficiency and have smooth response in upper midrange is key. TD6's with throat port maybe? Sorry my knowledge is limited, still learning hornresp...
post #6855 of 7535
I like it too.
How about upper and lower rows of 3" or 4" drivers, perhaps each tilted 45 deg to create a shallow V-shaped cavity.
Might be dicey, but perhaps the small height and depth of the driver cavity would keep phase cancellation under control above XO.
post #6856 of 7535
That sound similar to what Ive been playing with.
Couldnt figure out how to attach a sketchup file but if you search sketchup for SEOS Vifa tc9 it shoul pop up.
The model is pretty rough and doesnt show the cardoid loading Im considering in an attempt to lower the directed pattern down to 250hz or so.
post #6857 of 7535
That resembles some of the features of a Unity horn. Looks interesting for a center channel. If you make the box nice and wide and driven tapered like a Malcolm, you could get horizontal directivity to low mids and point source - ish behavior. Short wide ports above and below fed by rows of small mid drivers. . The little Gento 2inchers might be a fit for the mids (if you use enough of them). Just thinking out loud...
post #6858 of 7535
Originally Posted by noah katz View Post
I like it too.
More than a few do this in the pro market, especially with vertical/line array boxes. As with any such effort, it has a few possible pitfalls and benefits, with execution being key. The slot can make for a noticeable point of diffraction on the face, and the chamber can cause response changes and/or resonances which need to be dealt with. In general, the deeper the slot vs. the opening area, the more issues encountered.
post #6859 of 7535
The slot could be made a little deeper to allow rounding over onto the baffle.
It might require rear mounting, but if the opening is reduced in height until the distances are less than 1/4 wavelength, there ought not be any resonances.
Might doing this increase efficiency a la AMT?
Assuming AMT really does that; has that been verified, or is the efficiency just from greater radiating area?
post #6860 of 7535
Figured it out,
post #6861 of 7535
I think you guys are way over complicating the compact center idea. Just make it a 3 way! A row of six 2" drivers (Vifa TC6?) should be able to barely fit on a 9" baffle with the SEOS being 6.5" high. Couldn't the recess for the waveguide go to the very top of the baffle instead of leaving room at the top? A 6.5" - 8" woofer could then be placed on each side of the box and crossed in around 200-300hz.
post #6862 of 7535
Is there any way to know the weight of the speakers?
I want to wall mount mine.
post #6863 of 7535
That's exactly the method I was considering, but cost creeps up quickly that way. Ltd02's idea keeps it compact and 2-way. Although I think the construction complexity isn't worth it. I'd just eat the cost and go 3-way like you say. I was going to do SEOS12/DNA-205 over a few mids flanked by Eminence alpha 8a's. That gets a 4 ohm load, but about 97db/2.83V/m, about 9 or 10" tall, 80hz F3 sealed, and about $300. Just need to find a reasonable mid and I'd do it.
post #6864 of 7535
Quick question:
Will two 15s(side by side) work under a SEOS 12? What would the tradeoffs be in this situation?
post #6865 of 7535
I think not, nottaway. It's like the horizontal MTM center. The 15" is so big you'll have destructive interferences at modest angles in the 700 to 1000hz range. You be somewhat ok if you crossed low (like 900 to 1000hz) and made it a 2.5 way, but then you're faced with crossing where the CD may have power handling issues and directivity match issues.
post #6866 of 7535
I figured as much.
Sounds like id need the BFD750 on a 24" SEOS to make that work.
BTW i think that would be super sexy! Maybe a pair of 12s under that 24" horn......
post #6867 of 7535
Originally Posted by NicksHitachi View Post
I figured as much.
Heck yes, that would be sweet lookin'...black FG SEOS-24's w/BA-750 and a pair of TD12's. Come to daddy! tongue.gif
post #6868 of 7535
I figured as much.
Thats What I'm Talkin about!
post #6869 of 7535
You could also jump in the new project Matt and I are talking about starting now...SEOS 24 with dual 15s underneath biggrin.gif
post #6870 of 7535
If anyone is going to order the SEOS-24, they need to contact me fairly soon. The pallet is nearly full. In a week or so I'm going to go ahead and order random things to fill the rest of the pallet so we can get it completed.
