OK.. I'm going in full bore. With the SPRAY GUN...
Bought this gun http://www.gleempaint.com/noname.html as recomended..
My Epson 8350 will be 11' 6'' from my screen and seating will be right under projector....
I'm planning on mounting the projector and projecting on my Skim Coated Sheetrock to see just how big a screen I'm comfortable with given my 82'' Ceiling height... I'm thinking It will be 92'' - 98''... 102'' would leave me 16 inches at top and bottom and might be doable at Max.
My basement is light controlled. NO windows and My primary viewing will be FOOTBALL with some lights on with lights nearest the screen off all on dimmers.
From all that I believe my choice should be:
RS-MaxxMudd (for moderate ambient light)
16 oz. Delta Pearl Metallic #02601
12 oz. Delta Silver Metallic #02603
4 oz. Folk Art Champagne Metallic Gold #675
7 oz. UPW flat
16 oz. Minwax Polycrylic - Satin finish
12 oz. distilled/tap water**
As Per MM I will Blue tape 2" larger than my screen size before spraying and then I found the thread for wrapping the Felt on MDF Here http://www.avsforum.com/avs-vb/showt...218&highlight=
That's what I have so far, I'm at least a week out till spraying and I have to look for the step by step spray instructions again....
Do I Spray the Primer? Zinzer?
I think I'm having some anxiety issues here.
7 oz. UPW flat
However if there is a carpeted Floor above , myself I'd open up the Floor underneath the carpet, install a 12" x 12" x 3/4" Plywood blocking (wood glued in place) on the inside of the Sheet Rock above the Ceiling mount, drill a 1.5" hole through the Block, and simply screw the Ceiling plate on the ceiling uo and into the Plywood. Replace the small square of flooring, and re-stretch the carpet, and have that clean look that is so very cool.
